Golf mk2
sunroof rubber
Topic: sunroof rubber (Read 1826 times)
Reasty
Alpine white valver.
sunroof rubber
05 March 2011, 17:13 »
Evenin!
I'm in need of a bit of advice,just bought a new sunroof rubber for the mk2 (the felt one you see from outside the car) from gpc.
After having a look it would seem you have to remove the sunroof in order to replace the rubber seal,how do you do this and am I likely to run into any problems?,the roofs not leaking but the seal is all perished and looks crappy so want to replace it
Cheers!
The Mighty Elvi
I'm better than you today.
Re: sunroof rubber
05 March 2011, 17:23 »
It's in the Haynes manual, but basically whilst inside the car partly open the roof, prise off the trim panel and push it to the rear to expose the sunroof panel mounting screws and spring clips, and whip the lot off.
Lift the sunroof panel away carefully as there's a water trap fitted to the back end of it that you cannot see until it's out of the car.
Reasty
Re: sunroof rubber
05 March 2011, 17:36 »
Cheers buddy!
Thom89
Forum addict
Looking for an "Icebreaker"
Re: sunroof rubber
05 March 2011, 17:58 »
When you fit the new seal, try not to pull too much tension into it, if the seal contracts after fitting, it may leave a gap!
To cut the seal, side cutters are only OK, but will crush the metal within the seal! the very best way to get a perfect joint is to bind the seal in masking tape, mark the length you want, and cut in one go, with a rotary cut off wheel, like this...
http://www.youtube.com/watch?v=-3GnLIJn0Og
Thom
wurth
Re: sunroof rubber
05 March 2011, 18:02 »
http://www.golfgtiforum.co.uk/index.php?topic=33684.0
Benrevs
Re: sunroof rubber
06 March 2011, 11:49 »
Also when winding it back in the first time make sure the sunroof panel is sat all the way down, or you may scratch the hell out of it against the roof.
walchy01
Re: sunroof rubber
Reply #6 on:
29 April 2011, 19:18 »
+1, makes a real mess of the paint on the roof..
cняis
Know there's something burning over there...
Re: sunroof rubber
Reply #7 on:
30 April 2011, 00:18 »
Reasty where did you get your seal from?
Am I right in thinking theres an outer seal
and
an inner seal? My sunroof leaks with heavy rain and although the outer seal is knackered I'm not sure its 100% to blame. I suppose the other thing is blocked drain holes?
Quote from: oilman on 19 November 2010, 14:24
oakgreengolf
CAR FOR SALE PM FOR FURTHER INFO
Re: sunroof rubber
Reply #8 on:
30 April 2011, 07:15 »
You could not long back get them from vw but are around £45
Reasty
Re: sunroof rubber
Reply #9 on:
30 April 2011, 08:12 »
I got mine from chubnut on eBay,he sells genuine vag parts so it is genuine vw was about 50 quid,there is a outer and inner seal,this was just the outer one that I got,I believe you can get them from vw heritage/bigboystoys aswell.
Golf mk2
sunroof rubber
