Golf mk3
hardmonkeys
interior light stays on
Topic: interior light stays on (Read 1288 times)
Luke1981
05 March 2011, 13:46 »
The interior light switch ( doors open setting ) stays on when all the doors are closed and the ignition is on. I have checked all the electrical plungers on each door and they appear fine. Any ideas what might be causing this ?
Luke
MK IV GT TDI 150 PD / MKII CADDY SDI
mk3tony
GTI forum regular
Re: interior light stays on
05 March 2011, 13:58 »
Silly quesion but have you turned the switch off? Lol
2001 1.8T AUM - Rtech Spec 1 Custom Map, Catch Can, Cone Filter, 209bhp 237 lb/ft, SuperPro Wishbone and Rear Beam Bushes, Jom Coilovers, 19" BBS CH Reps
Luke1981
05 March 2011, 14:09 »
I checked that and its on the open door setting and just stays on. Obviously I can just turn the switch to the off position and leave it turned off, but a bet you the mrs will turn it on and leave it, and hey presto I get called to jump start the battery
*Jonnyg*
GTI forum regular
05 March 2011, 15:48 »
Mine does that sometimes!!! Really f*cks me off!
** Tuned diesels - kinda like a guy with a huge cock and premature ejaculation. **
mark-mk3gti
05 March 2011, 15:56 »
mine just started do this aswell! grr,
cant see anything obvious to cause it, cos if it was the door pin i dont think my central locking would work, however i could be wrong, gonna go check..
dom
10k hero
Back in a Mk4
05 March 2011, 16:20 »
Pop the little plastic cover off, remove the bulb and check for any moisture around the area. Mine did this a few weeks ago, i'm assuming that it was caused by moisture gathering around the light. I dried it all out and the problem was solved
Wayne
Sir Postalot
Reply #6 on:
05 March 2011, 19:50 »
Faulty door switch ?
Golf mk3
hardmonkeys
