Author Topic: mk2 golf 8v blitz chip  (Read 5248 times)
Offline Khare
  • The bear that khares
Re: mk2 golf 8v blitz chip
« Reply #10 on: 11 March 2011, 00:19 »
Not really. The chips controls ignition and fuelling, if you get it wrong you could damage the engine.
Offline danny_p
« Reply #11 on: 11 March 2011, 14:17 »
it's best to learn on an engine that is not your daily.
compareing chips is easy done,  then you can try each chip and see what goes best.  thats about as safe as it gets.
when you start pissing with them  checksums become a problem and you have to pay for the software that sorts them out for you.
but general AFR tuneing is easy and safe, shove a wideband lambda in your exhaust,  datalog it vs  manifold absolute pressure and RPM,  find your fuel map and offset it up slightly say 5% and do the same run again.
this will give you a good idea how much the adjustment in the map relates to how much adjustment in the actual AFR.   your looking for 12.5:1 at full throttel ( for basic mapping )   so you go back and adjust said map so drop it where you've gone past 12.5 :1  and increse it proportionaly where your still below it.  then do another run and see how close you got.
if you sit there and work the numbers you can start out doing it a lot more presicely get a pita with eeproms tho as you have to open the ecu every time you want to tweek unless you buy an emulator and there expensive.
as for spark thats where the power hides but also the risk,   on the fked old abf i used for testing i din't give a f**k so i just unplugged the knock sensors so it wouldn't back off the spark in it knocked and i just knocked the spark map forward in 2 degree steps  till it knocked then back 3 degrees when it did.
it much better to do it on a dyno tho as there is no point adding spark if your not getting more torque from it.  and you can see if drowning out the knock with fuel and adding more spark makes it go better or not.
all the VW's have gone bar 1.
Offline rossbarry1
« Reply #12 on: 12 March 2011, 13:59 »
and where can i get on of those?
Offline emery1990
« Reply #13 on: 12 March 2011, 18:22 »
Danny, if I was to take my car to a dyno, you rekon they would let me do my own thing on it, or do you rekon they would get funny about it. I'm not planning to get my car on the dyno and just do what you said, knock it back when it knocked.
But when it's all done I would like to know what power I get from my map, so could just do the spark then.
Offline danny_p
« Reply #14 on: 14 March 2011, 12:30 »
that one came off fleabay
Offline danny_p
« Reply #15 on: 14 March 2011, 12:31 »
just pay the guy who has they dyno.   cost of dyno is more or less cost of dyno + operator  and there skills will be significantly better than yours and they'll have it one a LOT quicker
Offline emery1990
« Reply #16 on: 14 March 2011, 18:02 »
True, my local dyno people dont touch ms they said, only emerald  :huh:
Offline danny_p
« Reply #17 on: 14 March 2011, 20:44 »
strange,  there will be somewhere thats happy to map it,   just get it running ok on idel before you go and you should be fine
Offline emery1990
« Reply #18 on: 14 March 2011, 21:13 »
I know, not sure it's because of a contract with emerald? Yer I'll get it running and put it on the dyno to have a look at the graph to see if it majorly needs tweeks, then get some more money up together and take it to r-tech probably, they said they can do it for £75 an hour.
