Author Topic: 16v gti brake  (Read 590 times)
Offline kylepeo
  • Vw's never die they just get lower !!
16v gti brake
« on: 04 March 2011, 22:45 »
ok guys fairly new to the golf scene and loving the mk3 apart from the faults  :cry:
got a few questions
i have a p reg 16v gti with no aircon it has abs (not working ) with the 288mm brakes have had it on fault code reader it said abs sensor (front drivers) fault so changed it and had fault codes reset but abs light is still on checked fuses all fine any idea ?????
also not sure what pads my car should have ie wear sensors or not ?
and there was a cut wire under the bonnet behind the drivers side bumper under the charcoal canister (am i right in thinking it should be for outside temp sensor cos my dash shows everything but that) or is it something else ?
other than the faults listed i am loving this car oh any idea how many lc3l are out there ??
thanks for any help guys
Vw\'s never die they just get lower !! :):)
