Author Topic: Mk3 VR6 Issues  (Read 2786 times)
Offline Leeds_182
Mk3 VR6 Issues
« on: 04 March 2011, 15:36 »
Hello,
I bought a mk3 vr6 as a doner car for my mk2 conversion a while back.
I checked over the car and there appeared to be no issues and drove it home fine. Since then, I have noticed some blue smoke from the car on start up and also a quantity of steam. This clears after around twenty seconds and the car runs fine but does smell like it is burning a bit of oil. I have checked the fuel filler cap and on the odd occasion there has been a very small amount of Mayo after a short run but there is no evidence on the dip stick.
Another problem I have is I am losing coolant. When I say I am losing coolant I mean I lose 2 litres after a drive! There is a definate leak coming from the back of the engine on the right as you look from the front.
I'm hoping the head gasket isn't going as the engine feels really strong!
Any ideas re where the leak may be coming from etc?
Cheers.
Re: Mk3 VR6 Issues
« Reply #1 on: 04 March 2011, 15:37 »
Sounds like the head gasket
Offline tdi_blu
  • Golf Gti & T4 2.5 tdi
Re: Mk3 VR6 Issues
« Reply #2 on: 04 March 2011, 15:48 »
My old VR use to get a very small amount of mayo under the oil cap,sometimes it can be because you do very short jorneys or if its left standing for some time or as you said could be the start of head gasket failure.If you have a water leak would it first be best to prove and fix that and see how you get on,it might be ok then.
Golf Gti
Offline Leeds_182
Re: Mk3 VR6 Issues
« Reply #3 on: 04 March 2011, 15:50 »
Before the crazy leak started the car was not losing any coolant at all.
If it is the head gasket is it worth saving the engine or just trying to find a new one?
Re: Mk3 VR6 Issues
« Reply #4 on: 04 March 2011, 15:51 »
Head gasket is not easy on the VR but should or will be worth saving.
Offline AudiA8Quattro
Re: Mk3 VR6 Issues
« Reply #5 on: 04 March 2011, 16:31 »
If it was losing that much water due to a failed headgasket then i think you would notice it when driving it!
Offline Leeds_182
Re: Mk3 VR6 Issues
« Reply #6 on: 04 March 2011, 16:36 »
Ha ha ha, I was thinking that.
Im hoping the blue smoke is valve seals and I can sort it out in due course.
Re: Mk3 VR6 Issues
« Reply #7 on: 04 March 2011, 18:11 »
Have you found the water leak?
Offline Leeds_182
Re: Mk3 VR6 Issues
« Reply #8 on: 04 March 2011, 18:33 »
It's difficult to see tbh as it appears to be dropping at the back of the engine and then dispersing. Someone said to me it could be a leak around the manifold but I'm not sure.
Re: Mk3 VR6 Issues
« Reply #9 on: 04 March 2011, 21:41 »
It could be your head gasket weaping, not a lot of coolant hoses on the back of the engine.
