Author Topic: Mk2 Jetta G60  (Read 303388 times)
Re: Mk2 Jetta Gti - new daily
« Reply #20 on: 27 April 2011, 23:10 »
Looks lush polished  :cool:
Offline VR6_Wherry
« Reply #21 on: 28 April 2011, 10:35 »
That looks sexy!  :cool:
Offline Simeon
« Reply #22 on: 03 May 2011, 22:41 »
Cheers for the comments
Things are moving a bit slower than anticipated as had to fit a new gearbox and a few other bits into my mates mk2, but finally got a day on the Jetta :)
Plan is to strip it out then add;
Gti interior
Black carpets
Front electric windows
Remote central locking
Mk3 fuel tank and wiring
Refurbed rear beam with poly bushes from other Jetta
New brake lines
Replace n/s rear plastic arch as it is scuffed
Weld necessary areas
Few pics of progress;
Nice tidy rear panel :)
But a little rot where the boot seal join is :(
Inside of car was pretty grubby so going to get a good clean;
Rear o/s arch needs a little bit of attention;
And then there's the usual spot where the fuel tank bolts in :rolleyes:
All this work means I can get the G60 engine ready and hopefully drop it in quite quickly - this is my daily so have to plan its garage time.
Offline Jack3559
« Reply #23 on: 04 May 2011, 09:28 »
Are you tackling the rust yourself?
Offline Simeon
« Reply #24 on: 04 May 2011, 10:27 »
Yep, gonna get it done today, car needs to be back on the road for the weekend
Offline Jack3559
« Reply #25 on: 04 May 2011, 10:36 »
Need pics.  :cool:
Wanna learn how to do this myself.
Offline Simeon
« Reply #26 on: 04 May 2011, 12:32 »
I'll take a few as I go. First step is to learn to weld mate, the rest you can make up as you go along :)
Offline Simeon
« Reply #27 on: 05 May 2011, 01:15 »
Didn't get as much done today as I'd hoped, but that always seems to be the way. Few pics, mostly self explanatory;
Snow foam and pressure washed the underside;
Then dropped the rear beam off;
Started tackling one of the arches, but as always when you start digging it gets worse;
Other side of same arch;
Offline Simeon
« Reply #28 on: 06 May 2011, 23:49 »
Bit more done today :) though welder was spitting at me loads which was a pain (literally!)
Chopped out the rot in the fuel tank mount;
Made up a patch, bit crude but fitted ok;
First patch on bottom of arch;
Second;
Third;
Formed the lip;
Welded up, just need to run the grinder over it in the morning :)
Offline Simeon
« Reply #29 on: 07 May 2011, 23:39 »
Tidied up;
Other side;
