Author Topic: Mk2 Jetta G60  (Read 284539 times)
Offline murraymint
Re: Mk2 Jetta Gti - G60 Conversion in progress :)
« Reply #180 on: 14 January 2012, 17:47 »
Any updates?
josh
Offline Simeon
« Reply #181 on: 18 January 2012, 16:22 »
Yeah, it's running, or rather it started up and idled badly for about 10seconds :laugh: Its not got radiator in it yet so didn't want to run it for long. Need to bleed the brakes and get last few bits hooked up then see if it'll run properly, need to find the time is all..
Offline Mr Blue
« Reply #182 on: 18 January 2012, 17:26 »
very nice sir :cool:
Offline Simeon
« Reply #183 on: 22 February 2012, 00:12 »
Cheers Mr Blue
A, seemingly monthly, update :tongue:
Brakes are giving me trouble, can't get a pedal, just goes to the floor :(
Decided to make the brackets for the intercooler;
It fits nicely on the cross-member on the n/s;
Had to make a bracket for the o/s;
Bracket to attach the intercooler to the radiator, just need to weld the two pieces together;
More same time next month :laugh:
Offline mk2 helper
« Reply #184 on: 22 February 2012, 02:53 »
only just spotted this thread but read through the lot of it and its awsome i love jetta's and what your doing with yours is brill.. love the good work and attention to detail hold in there it'll be so worth it in the end
if in doubt go flat out
Offline Simeon
« Reply #185 on: 22 February 2012, 11:22 »
Cheers mate :) Yeah got a bit of enthusiasm back for it now, hoping to put it on the road on April 1st (when tax runs out on my current daily mk3) and get it to Elsecar on the 9th.
Offline DanChave
« Reply #186 on: 25 February 2012, 08:13 »
I hope you do get it on the road soon man! I can't wait to see this up and running :)
Offline Simeon
« Reply #187 on: 13 March 2012, 00:15 »
Bit of an update, took Friday off work and got a bit done;
First up, set about getting the cam out;
Piper 285 in (obviously you can see the difference :laugh: )
Modified the slam panel to fit around the intercooler;
Bracket welded, painted and fitted;
Had to move the radiator over so no longer lines up with the slam panel;
Sorted;
Refurbed the starter motor;
Random shots;
Also fitted the bumper, then turned the key :D
Nothing :( not even a splutter, so gave up for the day.
Ultimate Dubs spured me on a bit, stripped the loom back and found a slight issue...
Fired up first turn of the key after sorting that :D
Only problem now is that I have an unwrapped loom draped over my engine :rolleyes: will get that sorted and see how it drives, surprisingly idled rather nicely this evening :)
Offline DanChave
« Reply #188 on: 14 March 2012, 16:28 »
Great news dude! Not long now  :cool:
Offline Simeon
« Reply #189 on: 16 March 2012, 00:06 »
Unfortunately going to be a bit longer ... 1 step forwards, 2 steps back;
Picking up new water pump and a few bits tomorrow then hopefully crack on and get it out for a run next week :)
