Author Topic: Anniversary Mystic Blue  (Read 115483 times)
Offline sharki786
  • GOT BOOST??
Re: Mystic Possible lol
« Reply #120 on: 07 May 2012, 19:59 »
Jeez those wheels were in a state, be good to see them looking all fresh and spangly again.
tell me about it. everyone was saying "sharki you need to sort your wheels out, they are letting the car down!" so off they went.
minor update, fitted ONE leather door card (front pas) well it took me all day as i got stuck. after pulling the half of the car apart (found a wire chopped for the alarm) so tried to sort that out while trying to find the best feed for the door card ligh, at the end connected it to the window motor (red/white & brown/white) (this is on the pas side) as that had cocstant power and worked with the switch. will upload pics.
yesterday i picked up a mate of mine (ozzie bizzle) and he was like WTF its like you have a spot light in here (LED's that i got of him) was funny seeing his face.
anyway will be uploading a pic of the door card and some more of the wheels (when i get some)
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
« Reply #121 on: 17 May 2012, 23:32 »
bit of an OLD update.
decided to take the drivers seat out and fix it up as it was f*cked!! both bolsters on the drivers was mashup (top & bottom)
anyway i got an anniversary pasangers seat from a guy that breaks mk3's
stripped it down
gave it a quick rinse:
reinforced the bolsters:
added some padding (foam)
thanks to mad4vw's he put it back together for me :cool:
« Last Edit: 17 May 2012, 23:36 by sharki786 »
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
« Reply #122 on: 17 May 2012, 23:45 »
my passangers leather door card:
fitted it in took ages as i had to wire the light. also as mentioned before, the boot sensor wire for the alarm was cut so had to reroute it down the drivers side, now all working  :cool:
door card light all hooked up and working as it should be. (thanks kells for the help!!) :wink:
*****MK4 GTI T*****
Offline Shady Pioneer
  • graphic designer.
« Reply #123 on: 18 May 2012, 00:14 »
How did you get the light wired in for the doorcard mate? My new leathers have these but obviously not wired in.
Offline sharki786
  • GOT BOOST??
« Reply #124 on: 18 May 2012, 00:48 »
piece of p1ss.
well atm i have only the passangers door card on. i connected my door card light wires to the window motor loom, look for the brown/white wire, which is the negative. red/white which is the possitive. conntect the pos to pos & neg to neg. make sure all other doors are closed and press n release the door switch light should come on when the switch isnt pressed and off when pressed. thats all i can tell you for now as i still aint had a look at the drivers yet, but when i do i will make a note of which wire to splice into.
*****MK4 GTI T*****
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #125 on: 18 May 2012, 01:02 »
Oh right so both the wires for the courtesy lights are already inside the door from the switch on the pillar?
Offline sharki786
  • GOT BOOST??
« Reply #126 on: 18 May 2012, 01:33 »
no they aint unless you have a highline. i tapped into the wire that goes to the elec window motor. i basicly stripped the wire back abit and connected to it if you see what i mean. (burned abit of the wire and peeled it back to expose the wire)
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
« Reply #127 on: 18 May 2012, 01:54 »
sorry thai-wronghorse. i cant remember what colour wires the door switch were.
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
« Reply #128 on: 19 May 2012, 00:43 »
got my wheels back few days ago w/o rubbers, gave them a good waxing:
wheel on left waxed up & right with wax:
how much wax i used:
put some meg tyre shine on to give it that wet look, came out realy well!! :cool:
got good reviews from my mates saying that they realy pull it all together!!
just need to sort out the calipers now.
« Last Edit: 19 May 2012, 00:49 by sharki786 »
*****MK4 GTI T*****
  • graphic designer.
« Reply #129 on: 19 May 2012, 01:44 »
They look awesome mate. Really suit the car. :afro:
