Author Topic: Mk2 won't restart when it hot  (Read 2694 times)
Offline ReillyGti
« on: 25 February 2011, 23:11 »
Iv got an E reg mk2 golf 1.8 16v gti with a kr engine and when I get in the car in the morning it starts up fine but if I drive down the rd to my work and turn it off and then try and start it again it won't start as easy it will start after a while but i don't under stand what's going on. Any one got any ideas?
Re: Mk2 won't restart when it hot
« Reply #1 on: 28 February 2011, 13:56 »
could be the fuel accumulator or non-return valve in the pump, need to get k-jet pressure gauges on it to be sure though I'm afraid.
try disconnecting the 5th injector to see if that helps, failing that disconnect the wur
Offline Dirtydodger
« Reply #2 on: 07 March 2011, 16:01 »
I get that in my mk4 but sometimes it doesn't even want to start when it's cold lol :cry:
MK4 Golf GTI mmmmmm sex on wheels...... ;-) <br /><br />A I\\\\\\\'m an Armourer, B I\\\\\\\'m an Armourer, C I\\\\\\\'m an Armour......
Offline DECKED-MK3-DUB
  • 1995 VR6 vento :)
« Reply #3 on: 09 March 2011, 21:32 »
Coolant temp sensor 100%, all golfs suffer from these, the sensor tells the ecu the engines cold when its hot and just over fuels it, some times the switch breaks down complety and they wont start hot or cold...
Offline AudiA8Quattro
« Reply #4 on: 09 March 2011, 21:55 »
Its a k-jet, mechanical fuel injection, no ecu.
  • 1995 VR6 vento :)
« Reply #5 on: 09 March 2011, 22:39 »
Yer i was on about mateys mk4 golf gti 8 v he's got lol... shoulda made myself more clear lol  :laugh:
« Reply #6 on: 11 March 2011, 00:09 »
I think i must of mis-read it  :embarassed:
