Author Topic: easy tuning  (Read 3560 times)
Offline danny_p
Re: easy tuning
« Reply #10 on: 27 February 2011, 23:00 »
Put a 1.8t in, or something adventurous like an R32/36?
whats adventurus about a 1.8T  tbh its now just a run of the mill engine conversion.  2.0 TFSI is adventurus
all the VW's have gone bar 1.
Offline tech1889
  • Mk2 GTI FTW !!
Re: easy tuning
« Reply #11 on: 27 February 2011, 23:07 »
+1 i think 2.0 tfsi is a good option not ben done that many times.. or as said r36 would be cool..
Offline shaolindan
Re: easy tuning
« Reply #12 on: 28 February 2011, 11:37 »
Golf GTi 8v mk2 1990
Coilovers, BBS RA, K&N Induction Kit...
Offline DOA
Re: easy tuning
« Reply #13 on: 28 February 2011, 12:26 »
If you really want to do something meaningfull, get a copy of Ricardo Wave (its on Isohunt if you look) and start learn about tuning the proper way, not by bodging a few bits of plastic out of an airbox. If you get good at it and understand the theory (it has some good tutorials) you could design your own cam profiles, exhaust systems, inlet manifolds etc etc using it although explaining how you got the package might be interesting.
Offline emery1990
Re: easy tuning
« Reply #14 on: 28 February 2011, 16:21 »
Hardly a bodge if it gives proven gains. I just read the word easy, and designing your own exhaust system doesnt go with easy lol
Offline danny_p
Re: easy tuning
« Reply #15 on: 28 February 2011, 23:46 »
i think DOA is refering to the type of tuneing i like.  where you work out exactly what is happening and WHY then you can make adjustments to optomise what is happenig to exactly what you want to happen.
when your doing proper tuneing you work out exacty what you want then work out how close you can ger with avalible resorces.  work out your cyl head then cams that determines the compression ratio, build the exhaust to suit the cams as best as space allows.  ect  there is nearly 280bhp NA in a 2.0 16v  but you have to do a f**king lot of work  like adding lots of weld to the ports and compltly reshapeing them
Offline Sam
  • Sam I am
Re: easy tuning
« Reply #16 on: 01 March 2011, 00:25 »
Tried to stay out of this thread but.... is this guy for real!?  :shocked:
Re: easy tuning
« Reply #17 on: 01 March 2011, 08:47 »
2.0TFSi is the future and engines will become more available in time.
Offline tech1889
  • Mk2 GTI FTW !!
Re: easy tuning
« Reply #18 on: 01 March 2011, 10:24 »
That's the problem at the moment you need like a 10k donor car
