Author Topic: speedo not working  (Read 2860 times)
Offline gazman1011
  • if your not first, your last!
speedo not working
« on: 23 February 2011, 16:51 »
hi all, well i have a mk2 golf pre 90, i had a look at the rear of the clocks its working there, where does it go after that, if not where is thecheapest place to get a speedo cable?
Re: speedo not working
« Reply #1 on: 24 February 2011, 09:14 »
how do you mean its working at the back of the clocks? have you drivenit with clocks out to ensure the speedo cable peg spins?
Offline gazman1011
« Reply #2 on: 24 February 2011, 14:22 »
no not driven it without the clocks in! took it all appart tho and had a look. and i spun the needle inside the clock and it moved! its another thing for the garage! lol
« Reply #3 on: 24 February 2011, 14:56 »
ah i see. drive it for a short distance with the clocks out and watch the cable, should see it spin. dont go too far as the battery wont be charging!
if its not spinning it could be the cable or the gear on the other end inside the gearbox
Offline Andy!
  • VR6
« Reply #4 on: 24 February 2011, 19:55 »
Apologies if this seems a hijack but the answer may be of use to the OP too.
@Rubjonny.
Does anywhere stock those detachable geared attachment from the gearbox end of the cable?
Unfortunately we don't seem to do them at ecp but surely someone does.
« Reply #5 on: 24 February 2011, 20:46 »
@Rubjonny.
Available from the dealers.  :smiley:
« Reply #6 on: 25 February 2011, 10:25 »
aye sometimes see them on ebay sold by chubnut as well
Offline Andy!
  • VR6
« Reply #7 on: 25 February 2011, 18:28 »
Ta blokes
