Author Topic: Magifoam - Now with pics  (Read 10416 times)
Offline xxpenxx
  • .: Eat Me :.
Re: Magifoam - Now with pics
« Reply #10 on: 24 February 2011, 19:14 »
Back on topic  :rolleyes:
I fiddled around with the +/- settings on the lance and gave the other halfs 206 a foaming, got it much much better :cool:
thats mad mate, talk about a quick top wash!!
Haze, so now I also need a applicator pad lol, pm me some cheap ok ones lol. was gona was the car 2mo :o(
Offline Dan J
« Reply #11 on: 24 February 2011, 20:02 »
yes Dom from your pics it looks like the mixtures not strong enough because your car should be thick with foam and that magifoam sits on the car for atleast 30mins.
« Last Edit: 25 February 2011, 00:09 by Purple Haze »
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #12 on: 25 February 2011, 14:56 »
dom you got a linky to this foam ?? i have valetpro ph neutral stuff and its good but feel could be better..
Offline Dan J
« Reply #13 on: 25 February 2011, 15:42 »
http://www.detailingworld.co.uk/forum/showthread.php?t=183611
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #14 on: 07 March 2011, 09:55 »
I got A LOT more foam from the super snow foam, now moving to cherry snow foam, although my lance from AB in the link you provided has stopped working after the 3rd time iv used it !
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline Dan J
« Reply #15 on: 07 March 2011, 11:35 »
:huh: whats happened dude??? have you checked the gause inside the unit, theres a small round pill shaped gause that can get clogged up and needs cleaning out.
strange you've only used it 3 times though and somethings gone wrong.
Offline F17BAD
« Reply #16 on: 07 March 2011, 13:56 »
dunno mate im well p1ssed off about it, was working fine, did rear of car tthen just went all gay and basically zero power, no foam and me having a p1ss would have more power
popped the standard lance back on and that works perfectly, im gonna strip down and check for blockage but they should not block after 3 times used. so as good as foaming is for me on a car that can mark with the slightest touch. the jury is out on the quality of the AB lance for me at the mo.
Sent them a PM on DW but zero reply (yet)
Offline Dan J
« Reply #17 on: 07 March 2011, 16:37 »
assuming theres no leaks from any of the joins etc, could well be a blockage somewhere and im putting my money on the gause.
do you flush the head out with warm water after each use?
Offline F17BAD
« Reply #18 on: 07 March 2011, 18:16 »
i didnt flush it out no mate, and i run a quite strong mix so hope it is just that, its coming apart tomo..
Offline Dan J
« Reply #19 on: 07 March 2011, 19:39 »
this is what the problem could be then dude, the gause are there to make the mixture foam up when passing through the lance and if left with strong solution on it it will get clogged up.
hope you can get it sorted mate.
