Author Topic: Clutch under warranty?  (Read 5516 times)
Offline Keithuk
Re: Clutch under warranty?
« Reply #20 on: 19 February 2011, 23:12 »
Well the longlife 40k service checks by Autodata are
Golf (08-) 2,0D TDI CR 2008-11  Engine code : CBDC
Service time (hrs): 1.90 it says 0.90 but thats wrong
 2.0020 Engine oil Drain/refill
 2.0030 Engine oil filter Renew
 2.0700 Brake pipe corrosion
 3.0100 Front brake pads Check/report
 3.0110 Front brake discs Check/report
 3.0190 Rear brake pads Check/report
 3.0200 Rear brake discs Check/report
 3.0310 Brake hydraulic system Check/report
 3.0380 Tyre condition Check/report
 3.0410 Tyre pressures Check/adjust
 3.0414 Tyre pressure monitoring system
 1.0160 Horn Check/report
 1.0180 Interior lamps Check/report
 1.0190 Front wiper blades Check/report
 1.0220 Front screen wash Check/adjust
 1.0230 Rear wiper Check/report
 1.0240 Rear screen wash Check/adjust
 1.0250 Headlight wash/wipe Check/adjust
 1.0260 Instrument illumination Check/report
 1.0270 Direction indicators/hazards Check/report
 1.0280 Lighting system Check/report
 1.0290 Headlight levelling system Check
 1.0300 Headlights Check/report
 1.0340 Sunroof guide rails Clean/lubricate
 2.0010 Engine oil leaks Check/report
 2.0017 Underbody pipes and hoses Check/report
 2.0080 Clutch hydraulic system Check/report
 2.0100 Gearbox oil leaks Check/report
 2.0153 Dual clutch transmission oil leaks Check/report
 2.0170 Auto transmission oil leaks Check/report
 2.0410 Steering joints Check/report
 2.0430 Steering rack/box Check/report
 2.0470 Steering column couplings Check/report
 2.0500 Suspension joints/seals/gaiters Check/report
 2.0560 Drive shaft joints/seals/gaiters Check/report
 2.0640 Road springs Check/report
 2.0650 Shock absorbers/mountings Check/report
 2.0670 Exhaust system/mountings Check/report
 2.0750 Underbody condition/sealant Check/report
 3.0260 Parking brake cables/linkages Check/report
 3.0414 Tyre pressure monitoring system Reset
 4.0065 Engine bay pipes and hoses Check/report
 4.0070 Washer bottle(s) Check/top-up
 4.0140 Coolant level/anti-freeze strength Check/adjust
 4.0760 Auxiliary drive belt/s Check/adjust
 4.1090 Air conditioning Check/report
 5.0090 Vehicle locks/hinges Check/lubricate
 5.0110 Headlamp alignment Check/adjust
 6.0010 Steering free-play Check/report
 6.0020 Clutch operation Check/report
 6.0030 Vehicle suspension operation Check/report
 6.0040 Engine performance Check/report
 6.0050 Transmission Check/report
 6.0060 Brakes Check/report
 6.0070 ABS function Check/report
 6.0080 Instruments Check/report
4.0570 Diesel primary fuel filter Renew| not listed but it should be changed every 20k
« Last Edit: 19 February 2011, 23:32 by Keithuk »
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline Keithuk
« Reply #21 on: 19 February 2011, 23:27 »
You don't say which year or engine Leon, Autodata says.
Leon (05-) 1,9D TDI PD 2005-10  Engine code : BXE
 1.0010 Brake servo Check/report
 1.0040 Footbrake travel Check/report
 1.0050 Parking brake travel Check/adjust
 1.0100 Fault diagnosis trouble codes Check/report
 1.0115 Instruments/warning lamps Check/report
 1.0130 Airbags/system Visual check
 1.0140 Switches/controls Check/report
 1.0150 Heater blower Check/report
 1.0170 Interior/exterior mirrors Check/report
 1.0320 Body work/paint Check condition
 1.0330 Sunroof drain tubes Clean
 2.0110 Gearbox oil Check/top-up
 2.0155 Dual clutch transmission oil Drain/refill
 2.0156 Dual clutch transmission oil filter Renew
 2.0320 Front differential oil leaks Check/report
 2.0330 Front differential oil Check/top-up
 2.0450 PAS hoses Check
 2.0540 Propshaft joints Check/report
 2.0575 Haldex coupling oil Drain/refill
 2.0576 Haldex coupling oil filter Renew
 2.0580 Rear differential oil leaks Check/report
 4.0031 Battery leads attachment to the bodywork Check
 4.0040 Battery electrolyte level Check/top-up
 4.0050 Battery condition/specific gravity Check/report
 4.0080 Brake fluid reservoir Check/top-up
 4.0210 Auto transmission level Check/top-up
 4.1000 Exhaust emissions Check/report
 5.0050 Service interval indicator Reset
Offline DRC
« Reply #22 on: 19 February 2011, 23:48 »
Leon was a 2008 2.0TDI PD FR :) but yeah, as you can see, alot more in-depth work on the Leons!
'13 Audi A3 8V S-Line - Dakota Grey - 2.0TDI 150 - MMI Plus Nav - Bang&Olufsen - Comfort Pack - LED Lighting Pack - Comms Pack - Model and Technology Badge Deletion
Offline The Doc
  • E63s Estate - Vito Sport
« Reply #23 on: 20 February 2011, 08:20 »
It must just be me but it feels fine today? Maybe because I've been so used to an auto?
Doc, Monday sees the first mods of de-badging and my HIDS :) may clean the engine bay as there seems to be a lot of oil near the drivers headlamp area? :S
Happy days, don't forget a photo  :wink:
