Author Topic: How do you take apart a fog light  (Read 4781 times)
Offline Adamdubz
Re: How do you take apart a fog light
« Reply #10 on: 21 February 2011, 16:17 »
i dont get it is that the inside bit ?? that has the Magnifier on ?
« Reply #11 on: 22 February 2011, 09:41 »
heres my guide:
http://www.clubgti.co.uk/forum/showthread.php?t=215836
the bit that is metal on the mk3 fog lamp is the brown bit where the bulb sits, you can just see all the peeling chrome in one of the pics. the white bit is similar on the mk3 lamp but it only has 1 adjuster hole.
you dont have to strip the mk3 housing like in the links above, i did this because the mk3 fogs i got had both the adjusters snapped off. so i stripped the mk2 and mk3 housings down, then swapped the mk3 metal bit into the mk2 white adjuster bit :)
