Author Topic: DRL configurations  (Read 4133 times)
Offline DRC
Re: DRL configurations
« Reply #10 on: 17 February 2011, 15:45 »
I though the match model upwards has auto lights/wipers?
'13 Audi A3 8V S-Line - Dakota Grey - 2.0TDI 150 - MMI Plus Nav - Bang&Olufsen - Comfort Pack - LED Lighting Pack - Comms Pack - Model and Technology Badge Deletion
Offline The Danno
« Reply #11 on: 17 February 2011, 16:37 »
On the R, if you just have DRL's on, i believe the tail lights remain OFF. If you put on side lights, the DRLs go dimmer and the rear tail lights come on.
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #12 on: 17 February 2011, 18:11 »
This may work
Using VCDS
Central electric---coding--->  long code helper
Byte 11 select it
A box below will come up
A tick box next to 'Daytime running lights via low beam' will unticked, tick it. click back, click 'do it'.
Current Garage:
35+ years of GTI ownership.
Offline DRC
« Reply #13 on: 17 February 2011, 18:26 »
Same as the Rocco then snoopy?
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #14 on: 17 February 2011, 20:46 »
Its how the xenon equipped cars are setup. Mine was setup like that so it had front and rear lights on all the time as DRL. I had to untick that box to turn off my DRL.
Current Garage:
Offline jamojdm
« Reply #15 on: 17 February 2011, 23:07 »
SE/Match upwards apart from the GT  :angry:
GT TSi, Deep Black, Convienience Pack, 2 Zone Climate Control, RNS510 - Looking to add Bluetooth
Offline dubber36
« Reply #16 on: 18 February 2011, 07:47 »
This may work
Using VCDS
Byte 11 select it
Cheers Snoopy.
The only issue I can see with that having hallogen headlights is shortened bulb life.
I need to get myself an up to date VCDS cable so that I can do this myself. I reckon we'll run normal DRLs through the summer, then low beam headlights when the clocks go back. Now if only the car could do that itself. It can't be beyond the realms of possibility.
