Golf mk3
hardmonkeys
Drive shaft / CV Boots
Topic: Drive shaft / CV Boots (Read 2902 times)
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Re: Drive shaft / CV Boots
Reply #20 on:
25 February 2011, 10:01 »
cv glued into hub, not cv glued to shaft
as i say its done on some VR6 models, i have no idea why but there you go
AudiA8Quattro
Forum addict
Reply #21 on:
25 February 2011, 11:20 »
What Jon means is on some models the splines have loctite put on them from factory.
The outer cv joint splines that is.
I've seen this on a mk3 gti 16v, as well as a vr6.
I needed a hub puller to separate the shaft from the hub both times.
harlemex
Reply #22 on:
25 February 2011, 16:20 »
I see what you mean now. I needed a hub puller too,thought this was because the shafts are wedge shape, and they get quite literally wedge right in./
Golf mk3
hardmonkeys
