Author Topic: Mk3 2.0 8v gti wiring loom swap  (Read 1157 times)
Offline lukehod999
« on: 16 February 2011, 16:42 »
hi, my mk3 gti gearbox recently went and ive now bought a new mk3 gti with wiring problems in the hope of making a good car out the two. Ive decided to use my old gti with the gearbox problems for spares. Is it a big job to switch the ecu and all the wiring loom into my new car ? any help appreciated.
Re: Mk3 2.0 8v gti wiring loom swap
« Reply #1 on: 16 February 2011, 16:50 »
What year are the cars, should be easy enough to sort.
Offline lukehod999
« Reply #2 on: 16 February 2011, 16:56 »
both 1996 models . thanks for the quick reply
« Reply #3 on: 16 February 2011, 21:19 »
In that case, will be a straight forward swap over, take pics as you go (always help later if you cannot remember where a plug goes) and take you time.
« Reply #4 on: 17 February 2011, 09:45 »
hardest part is unplugging fusebox end, as i think the brake servo has to come off the bulkhead to get the wiring out from behind it? not 100% sure on a mk3 but you do on a mk2 at least.
Offline lukehod999
« Reply #5 on: 18 February 2011, 00:22 »
thanks , ill let you know how i get on
Offline Khare
  • The bear that khares
« Reply #6 on: 18 February 2011, 00:30 »
Yup brake servo will have to come out to access the hole in the bulkhead.
