Author Topic: More Problems  (Read 2748 times)
Offline LowlifeDubber
Re: More Problems
« Reply #20 on: 17 February 2011, 18:30 »
Yeah gimme a shout,i got a full head with inlet and hedgehog and exhaust manifold.Dizzys,new caps and rotor arms etc.Will be a full engine up for grabs as soon as i get the bloody thing out and a vr6 in. :grin:
Offline Leon27
Re: More Problems
« Reply #21 on: 17 February 2011, 22:23 »
I had a 1.8 ADZ and had the same problem which turned out to be the coil. I couldn't figure it out because there was a spark on the King lead when the problem occurred so I also changed the fuel pump relay, the throttle mounting plate and coolant temp sensor.
It would never happen in the middle of the day cold start, just on early mornings which was weird. Used spark plug testers and noticed that the sparks were very very weak and got stronger after more cranking until it fired up. Apparently if the coil pack has a crack on it then dampness/moisture can settle in.
If you can, donor a coil when the fault happens. If you have done so already then hopefully the CTS will solve your problems as thats definately the next thing to measure. Have you scanned it for faults?
Offline Gal
Re: More Problems
« Reply #22 on: 23 February 2011, 15:02 »
Did you fix it? Mine has started jumping and losing power again. I changed the coil. Dizzy cap and rotor arm. Temp sensor near top of engine. Still to do plugs. Thermostat can't be working at all and open as car don't get hot unless sat running in carpark. Even then air out of heaters are barely warm. I have cleaned the throttle body using carb cleaner. Seems worse when damp and running hot. I'm actually now waiting for it to cool down as it's jumping like skippy
