Author Topic: ECU dodgy help!  (Read 4684 times)
Offline Len
Re: ECU dodgy help!
« Reply #20 on: 23 February 2011, 16:14 »
Change the ecu relay! :grin:
www.sas.org.uk
www.the-ace.org.uk
Offline javalin
Re: ECU dodgy help!
« Reply #21 on: 23 February 2011, 16:16 »
>Yeah but the fact that injectors 1 and 3 have no life then it sounds like an electronic problem rather than an issue with the distributor/leads/plugs.
but seperate problems surely? Ign coil is firing so he should get 4 x Sparks, but if the injectors aren't running either:  (1) broken injectors, (2) bad wiring or (3) transistor drivers faulty on ECU
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Re: ECU dodgy help!
« Reply #22 on: 23 February 2011, 16:19 »
The more I read the more I think you have a ecu problem  :undecided:
Quite likely that will be the solution, but why isn't the getting a spark for all plugs past the dizzy?  Thats got to be dizzy, lead or plug related.
James
I think they are 2 faults as such, injector problem cannot really be much more than the ecu as that is all that really controls them.
Offline javalin
Re: ECU dodgy help!
« Reply #23 on: 23 February 2011, 16:27 »
or bad wiring, or bad injectors or bad sensor(s) (crank/cam).  Makes sense to prove these before condemming the ECU I'd of thought.
At the end of the day - it just does what it knows howto based on its inputs.
James
Offline valver3g
Re: ECU dodgy help!
« Reply #24 on: 23 February 2011, 17:23 »
Khare> how much do you want for the ecu? whats the code?
Offline Khare
  • The bear that khares
Re: ECU dodgy help!
« Reply #25 on: 23 February 2011, 17:33 »
ECU is 037 906 024 AB  :smiley:
You have PM on the way  :smiley:
Offline valver3g
Re: ECU dodgy help!
« Reply #26 on: 24 February 2011, 09:28 »
Javalin/james> well ive changed the crank sensor already, and if it was the crank sensor surely it wouldnt get a spark at all? or does it use seperate notches on the crankshaft/ flywheel to tell what the position of the piston is in each cylinder? ive tried with the dizzy unplugged but i only checked the spark not the injectors,il do that on saturday. it has no mass air flow sensor, only air temperature and intake manifold pressure sensor, but il try unplugging them.
is there a micro relay for each injector within the injector rail or is that all in the ecu? yeah its multipoint.
il try checking 2 and 4 leads again
il try what youve suggested sensor wise, if all fails i think its going to have to be a different ecu.
does anyone know how to recode an ecu with vcds/vagcom?
Offline valver3g
Re: ECU dodgy help!
« Reply #27 on: 24 February 2011, 09:30 »
Khare, AB is the un-immobilised ecu isnt it? yeah the price u sent sounds ok. il let u know buy the begining of next week as im going to have one last try at it on saturday.
Offline Khare
Re: ECU dodgy help!
« Reply #28 on: 24 February 2011, 12:31 »
I THINK it hasn't got immob. Reason I say it is because it's pre 95 ECU, AE and BE were used after that. Someone will confirm though  :smiley:
Re: ECU dodgy help!
« Reply #29 on: 24 February 2011, 14:03 »
thats non-immob ecu aye, superceeded by 037 906 024 G then 037 997 024 GX
