Author Topic: golf gti 1.8 box into a golf gti 2.0?  (Read 1470 times)
Offline boneybradley
  • Back in a Mk3...
Re: golf gti 1.8 box into a golf gti 2.0?
« Reply #10 on: 13 February 2011, 22:08 »
So essentially a poor mans GTI.
If you say the driver and se are a poor mans GTi then yes (I had a driver due to insurance costs when I was younger!)
this is a 1.8GT spi
« Reply #11 on: 14 February 2011, 11:02 »
regardless, the answer is yes, but you need to change the clutch friction disc for a 1.8 mk2/3 one.  if you go for a complete clutch kit be aware there are 2 different ones depending on the age of the car. check your flywheel, if it has 2 dowels its an early one and uses same clutch as mk2 1.8 8v/16v (8v same as mk3 1.8 8v, 16v same as 2.0 8v) if it has 1 dowel then its late mk3 and only late type 1.8 8v mk3 clutch kit will fit.  other option is to buy an early mk3 or mk2 2 dowel clutch kit,m then you know 100% that a mk2 clutch kit will fit, which generally are cheaper to buy than the later spec mk3 ones.  if i were you i would get a mk3 flywheel and have it lightened then buy mk2 1.8 8v clutch kit, then you know it will all fit.
check the box code before you do anything though, it may not be what the seller thinks it is. and as a last check before you start try to fit the clutch friction disc onto the input shaft then you know 100% that it will all bolt together
Offline darcy
« Reply #12 on: 15 February 2011, 12:48 »
saw loads of these GT's when i was in andorra (there everywhere), does not help or answer the question but now i know what engine they have. :)
