Author Topic: had enough now  (Read 2917 times)
Offline danmusic24
Re: had enough now
« Reply #10 on: 12 February 2011, 16:52 »
if you have replaced everthing then its got to point to ecu issues....again like i said before i spent ages trying to fault find and after spending sh!t loads on replacing pretty much everthing it came down ecu....join the rac they know there stuff :smiley:dont give up mate
Offline JC
  • Back in the North.
Re: had enough now
« Reply #11 on: 12 February 2011, 16:55 »
some had similar with a mk3 anni ( cant rmember his name )
Earth lead issues were at fault if i remember correectly.
sure someone will be along soon t correct or fail me
Offline neil1780
Re: had enough now
« Reply #12 on: 12 February 2011, 17:08 »
jsut does the same with another ecu mate still nothing. tried earthing coil to block block to battery coil to battery still the same.
V6 4MOTION
Offline stella
Re: had enough now
« Reply #13 on: 27 February 2011, 19:10 »
wot about ignition switch every thing goes through that might be worn if not imobilisor
Re: had enough now
« Reply #14 on: 27 February 2011, 19:14 »
No spark has to be the coil pack. :smiley:
Offline Khare
  • The bear that khares
Re: had enough now
« Reply #15 on: 27 February 2011, 19:23 »
Is the ECU relay new?
Offline danmusic24
Re: had enough now
« Reply #16 on: 27 February 2011, 19:37 »
thought it was running mate? :wink:
Offline AudiA8Quattro
Re: had enough now
« Reply #17 on: 27 February 2011, 20:09 »
Which engine?
Have you checked the hall sender?
Offline neil1780
Re: had enough now
« Reply #18 on: 27 February 2011, 22:00 »
Tis running now mate sweet as just need some tax and insurance an were on the road. Someone brought the post back up.
V6 4MOTION
Offline Khare
Re: had enough now
« Reply #19 on: 27 February 2011, 22:06 »
What was the problem? Would be good to post a nice write up of what you did/changed so people can find the fix in the future  :smiley:
