Author Topic: digital gear indicator missing from DIS - FIXED  (Read 15631 times)
Offline ajmoir36
Re: digital gear indicator
« Reply #10 on: 10 February 2011, 21:25 »
Actually my clocks arn't any of the versions that can have staging 5K6 920 970 E
Staging feedback here:
Found in Adaptation (when supported). From the drop down list, choose Staging. Change to On and Save.
MkVI Instrument cluster - which one do you have?
Please update that thread with your info. It looks like the Golf / Jetta 5K6 920 870 D and 5K6 920 970 H will activate. Also note the 2009 Seat Leon with 1P0 920 850 B
Maybe thats something to do with it, i'll vagcom at the weekend to see if i can spot it aywhere.
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline Keithuk
« Reply #11 on: 10 February 2011, 23:29 »
Cheers ajmoir36 I shall have to have a look sometime.
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline ajmoir36
« Reply #12 on: 12 February 2011, 12:31 »
Right had a quick look with the Vagcom, could not find anything to suggest turning on the change gear indicator in any module.
Although did find this I assume if I started the car it will display the gear number? or up/down.
Details:
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 5K6 920 970 E    HW: 5K6 920 970 E
   Component: KOMBI         H03 0305
   Serial number: 00000000000000
   Coding: 470F00
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
   ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
   VCID: 3669DD8838C1
No fault code found.
Control Module Part Number: 5K6 920 970 E
  Component and/or Version: KOMBI         H03 0305
           Software Coding: 470F00
            Work Shop Code: WSC 01357
                      VCID: 3669DD8838C1
Advanced Identification/FAZIT
     Identification: VDD-024
     Date: 12.03.10
     Manufacturer number: 1901
     Test stand number: 3779
Flash Status
     Programming Attempts(application): 0/0/0
     Successful Attempts(application): 0/0/0
     Programming Status: 00000000
     Flash Date: 00.00.00
Software
     BAP: 01.04.01
     OSEK-OS: 03.14.00
     HiSpd Net: 01.10.00
Misc.
     Hardware number: 5K6 920 970 E
     Workshop System Name: J285
     Equipment/PR Code: 2D2D2D2D2D2D2D2D
     ASAM Dataset Revision: A04052
Car Info
     Chassis Number: WVW------------------------
VCDS Info:
Offline Keithuk
« Reply #13 on: 12 February 2011, 13:15 »
Cheers, are you using the older Vagcom or VCDS or is that just a play on words?
Offline ajmoir36
« Reply #14 on: 12 February 2011, 14:18 »
Latest and greatest 10.6.3 VCDS, Vag com same thing really.
Offline Keithuk
« Reply #15 on: 12 February 2011, 16:24 »
Yes they changed the name in May 2008. Its just that if people still call it VAG-COM then they could be using the older versions.
Revisions
Offline p3asa
« Reply #16 on: 13 February 2011, 10:59 »
FFS the guy is trying to do you a favour and all you can be is pedantic on the name of the application used.
Offline The Doc
  • E63s Estate - Vito Sport
« Reply #17 on: 13 February 2011, 11:04 »
 :grin: :grin: :grin:
I use VCDS coz it's shorter  :wink:
Offline ajmoir36
« Reply #18 on: 13 February 2011, 11:20 »
Wo hoo don't start I fight I don't mind.  I suppose he is checking to see if I have the free'r version of Vagcom rather than the paid version of VCDS.  I have the paid one as there are now 5 VAG cars in my family, so figured its worth buying it. Two mk5 Golfs, one mk6 Golf, one mk4 Bora and one Audi Estate.
Back to topic.
Offline The Doc
« Reply #19 on: 13 February 2011, 11:23 »
What's all this? Well have no trouble here  :grin:
