Author Topic: Mk3.5 cabriolet VR6 supercharged (TT dash 90% fitted :) )  (Read 112911 times)
Offline ian_GTI
Nice work. Is everything working. Electrically?
Yep got 95% of it working
The rev counter doesn't as it's can bus and the fuel gauge works backwards lol apart from that it's getting there
What's the differnce in the shifters, I've got the TT gator to go on was just hoping it would fit with a bit of modding
Offline tshirt2k
  • Been there...Done that...
02J shifters are alot better. More precise. But I suppose the gaitor and knob can be fitted with a jubilee clip. Same as mk4 on a mk3
Mk3 ABF 16VT Megasquirt V3
Offline mark-mk3gti
Looks mint!
How can u sort the rpm counter? Fuel gauage shouldn't be too bad should it? Or am I totally wrong and underestimating the work? :)
Offline ian_GTI
Fuel gauge ain't to bad but when you fill the tank up the gauges will beep etc
I'm going to see if I can fit a mk4 fuel sender in the tank and that should make it go the right way
Rev counter I have a plan for but that will be reviled in time :)
Also the gauges are looking for sensor inputs I don't have like oil level etc so so there beeping like mad
I'm going to see what I can bypass if not I will have to find what resistance each sensor is that it's looking for and just put a resister in to trick them into thinking that the sensors are there (if that makes sense)
Offline lemski
  • 16v
Cant u get aftermarket sensors plummed in so you have the readings there if you choose to use them
Offline ian_GTI
Not really as simple as tbh lol
Offline dan_apps
  • too low for british roads!
havent seen this thread before but serious kudos to you Ian epic build and i love it! :cool:
that dash must have been a nightmare to fit, how much of the crash bar did you need to cut out?
Offline ian_GTI
The only bits left are the n/s bit the mounts the heater box and around the steering column, then I made up some reinforcing braces to go in the middle
So yeah not alot left of in :)
Offline jv
  • Administrator
nice work :afro:
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline tech1889
  • Mk2 GTI FTW !!
Love it mate great work for fitting that
