Author Topic: pick up coil problem  (Read 848 times)
Offline matping
  • MK1 20vT MK5 GTI T
« on: 08 February 2011, 18:46 »
hi guys had a problem with my car starting so did a scan with vag com and it says  immobiliser blocking engine from starting ( pick up coil) so i eventually found the fault  . on the ignition barrel is a type of scanner that scans the key i presume then tells the immobiliser to let the engine start  . and this is snapped off ! so can i just got get anouther 1 of these from a breakers yard as its a 2 min job to fit ?. will it recognise my key tho as the scanner ( pick up coil ) is off anouther vw ? or do all the keys have a  code the scanner will know?.   :rolleyes:
Offline andc1
Re: pick up coil problem
« Reply #1 on: 08 February 2011, 19:14 »
all coded i would imagine
Offline matping
« Reply #2 on: 08 February 2011, 19:26 »
the reader ill be putting on is just a reader aint it ?  ill give a try suppose it not harm hey ?
« Reply #3 on: 08 February 2011, 23:18 »
I believe it will need coding.
