Author Topic: steam coming out of heater vents  (Read 1982 times)
Offline trevg
« on: 08 February 2011, 17:19 »
some advice i have steam coming out of my heater vents but if i put the heater on full speed it clears but if the the heater is turned off and then restarted it does it again    would this be the  :angry:  :undecided:
Offline dubber36
Re: steam coming out of heater vents
« Reply #1 on: 08 February 2011, 17:40 »
Scuttle drain holes may be blocked causing it to fill up with water. The water will then be coming in through the heater air inlet and being blown out as steam.
Offline swampy50
« Reply #2 on: 08 February 2011, 17:59 »
Mine did this and was the heater matrix. I think when the fan was on it heated the window enough not to mist up, but when it wasn't steam would come out (well more a mist than kettle steam).
Offline jocarl11
« Reply #3 on: 08 February 2011, 18:06 »
+1  Sounds like heater matrix to me, Water leaks into heater box from the burst matrix causing the steam.
« Reply #4 on: 08 February 2011, 21:35 »
Heater matrix failed
« Last Edit: 18 February 2011, 15:08 by Wayne »
Offline oldskooldub
« Reply #5 on: 09 February 2011, 22:46 »
+3 deffo matrix not as bad a job as it seems though
« Reply #6 on: 09 February 2011, 23:31 »
Mk2 is easier than a mk3 from what I have read.
Offline trevg
« Reply #7 on: 10 February 2011, 11:32 »
thanks for the replies fellas got a new decent matrix from gsf gonna start ripping the old girl apart saturday   :smiley:
Offline rob.043
« Reply #8 on: 10 February 2011, 11:38 »
Be sure to throw away the bypass valves from the heater matrix feed and retuen pipes, you wont need them with the new matrix. I  think details are in the 'how to' in the maintinance section, its a good guide.
