Author Topic: Different colour pads?  (Read 5336 times)
Offline bonny
Re: Different colour pads?
« Reply #10 on: 09 February 2011, 22:30 »
Thanks for the replys lads very helpfull  :smiley:
To be fare i didnt put the pads face down  :tongue:
Is the porter cable a decent model?
The more you pay The faster you go.....
Offline waxamomo
« Reply #11 on: 10 February 2011, 07:19 »
Yep good machine  :wink:
Offline bonny
« Reply #12 on: 11 February 2011, 15:04 »
^^^ good to know  :cool:
It looks like the pads are SONUS, so what colour does what?
I need to get rid of swirl mark's  :rolleyes: Then is it a polish & wax to finish off?
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #13 on: 12 February 2011, 12:25 »
your polishing to get rid of swirl marks so once paint is swirl free just a couple of coats of sealant and then wax..
Offline bonny
« Reply #14 on: 12 February 2011, 15:47 »
ok thanks. So what's the best sealant and wax you guys use?
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #15 on: 12 February 2011, 16:20 »
at the moment as its winter im using.. jeatseal 109 sealant which is the muts nuts
and for wax im using collinite 845 as its very hardy and long lasting in the summer i use dodo juice light fantastic
Offline bonny
« Reply #16 on: 13 February 2011, 21:36 »
That's great, thanks  :smiley:
Am still unsure what colour pads do what though  :undecided:
Offline Dan J
« Reply #17 on: 13 February 2011, 22:25 »
have a feel of the pads, the yellow one looks like a stiff ridgid pad and may be an intesive cutting/compounding pad, the green one im not sure about, the orange and blue ones could be a finishing pads and should be really soft and easy to squeeze. the other two purpley ones could of started out white in which case are swirl removing pads.
http://www.waxamomo.co.uk/productcart/pc/viewCategories.asp?idCategory=96
http://www.i4detailing.co.uk/acatalog/Sonus_SFX_6_Pads_1.html
« Last Edit: 13 February 2011, 22:28 by Purple Haze »
Offline bonny
« Reply #18 on: 14 February 2011, 18:25 »
Just what i was after, thanks  :smiley: Your right about the feel test.... the yellow ones are stiff (would they be ok for say after flatting a bumper with 800 then 1200 grit paper?) What compound would i use for this method to polish up?
The green, orange & blue pads are very soft to touch, so would these be used to apply sealant & waxes?? Sorry for the noob questions  :undecided:
Thanks again  :smiley:
Offline waxamomo
« Reply #19 on: 14 February 2011, 19:58 »
You could really do with following 1200 with 2500 or 3000, that would make it easier to polish out.
The softer pads can either be used for a finishing polish to bring up the shine, or apply the sealants as you have said.
