Author Topic: Crap radio reception  (Read 3961 times)
Offline tdi_blu
  • Golf Gti & T4 2.5 tdi
Re: Crap radio reception
« Reply #10 on: 08 February 2011, 11:33 »
Pretty sure the one on ebay is the one I needed the other type of connector is ISO have a look at this other link and you will see the one you need once youve looked at the rear of your radio  :wink:
http://www.nexxia.co.uk/products.asp?category=Antenna%20Adaptors&section=Car%20Audio
Looking at that I would say the common one for vw would be ISO to DIN bottom one.
« Last Edit: 08 February 2011, 11:36 by 16v_blu »
Golf Gti
Offline Khare
  • The bear that khares
« Reply #11 on: 08 February 2011, 11:36 »
Ahh, mine is din. SO the one you got is the one that will fit mine  :smiley:
Offline tdi_blu
« Reply #12 on: 08 February 2011, 11:50 »
 :grin: as I said just take the radio out and check the your system is DIN and then check the end of the arial out to make sure its that ISO connector if it is then yes thats the one but check dont want you blaming me if its wrong  :grin:
Golf Gti
Offline Khare
« Reply #13 on: 08 February 2011, 12:01 »
The aerial has a din end, so yup, din  :grin:
Offline Len
« Reply #14 on: 08 February 2011, 12:48 »
Sorry Khare, I wasnt really looking at where your aerial was! :grin:
www.sas.org.uk
www.the-ace.org.uk
Offline Khare
« Reply #15 on: 08 February 2011, 12:52 »
No worries  :smiley:
Offline boneybradley
  • Back in a Mk3...
« Reply #16 on: 08 February 2011, 13:31 »
you can buy aerial boosters (amps) that keep your original aerial and only need a live feed (blue) and the aerial lead plugging in (and then connecting to the radio)
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #17 on: 08 February 2011, 20:03 »
I listen to talk sport alot and my arial was pants but bought one of these signal amps and its perfect now get all the stations and there easy to fit.
http://cgi.ebay.co.uk/Car-Antenna-Radio-FM-Am-Signal-Amp-Amplifier-Booster-/170593652801?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27b82c9041
Offline harlemex
« Reply #18 on: 11 February 2011, 15:42 »
I tried an aerial booster on my roof mounted aerial and it made no difference, may work on wing mount tho. My roof mount is so crap it works just the same not being plugged in at all. Any ideas why this is?
Offline tdi_blu
« Reply #19 on: 11 February 2011, 21:30 »
Mine works a treat and Its a big improvement are you wiring the blue wire up correctly ?Failing that what I had to do with my old VR was remove the lower part of the dash under the glove box passager side and trace the arial wire down and you should find a kind of plug joiner there mine on my old VR had been cut by its former owner god only knows why but I went the scrap yard found another one plugged it in  and it worked a treat worth a look anyway  :wink:
Golf Gti
