Author Topic: Coil sparks?  (Read 1715 times)
Offline Gal
Re: Coil sparks?
« Reply #10 on: 07 February 2011, 12:28 »
take the trim off under the windscreen wipers, then its two nut/bolts one on either side.  Undo, replace and refit, and don't drop the nuts!  The trim fixings need rotating and a gentle lift with a flat bladed screwdriver to come out.
Easy.
J
Were they normal bolts? I think we saw 2 with star shaped heads. What they called called again? lol
Offline javalin
Re: Coil sparks?
« Reply #11 on: 07 February 2011, 12:35 »
yup normal bolts - 10mm I think.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Gal
Re: Coil sparks?
« Reply #12 on: 07 February 2011, 12:46 »
Any chance you could take a pic and then I could see if its the same as what I think I saw last night?
Thanks :smiley:
Offline javalin
Re: Coil sparks?
« Reply #13 on: 07 February 2011, 12:50 »
not easily no. Its just standard bolts. If your's isn't - then you'll have to get a tool which works on them.
Offline Gal
Re: Coil sparks?
« Reply #14 on: 07 February 2011, 13:10 »
No problem
Hope GSF has one in stock later
Offline Gal
Re: Coil sparks?
« Reply #15 on: 07 February 2011, 17:46 »
Got a coil from GSF
Fitting plus took cover off the throttle housing and it was full of oil.
Sprayed carb cleaner through and ran it a while
Drove back home, still a bit hesitant though
Got a temp sender too but not fitted as the temp gauge does go up to half (in traffic) but doesn't blow out hot air through the vents and the gauge goes back down while driving
Offline javalin
Re: Coil sparks?
« Reply #16 on: 08 February 2011, 08:45 »
a new thermostat also needed then.   temp should sit at 90 degrees always.
