Author Topic: V6 4 Motion BIG PROBLEM!!!!! I NEED HELP!!!!  (Read 3958 times)
Offline kevjenkins
  • VW ITS A RELIGION
« on: 06 February 2011, 16:30 »
Right i have a bit of  a problem with my v6 4 mo golf it runs ok on short journeys BUT if i travel or use it for more than 30 mins none stop i really sturggle to start it after its like theres no fuel cause it will start breifly and if i i feather the throttle i can keep it going and eventually it may clear and run ok !?
Any ideas ????
Offline cullygti
Re: V6 4 Motion BIG PROBLEM!!!!! I NEED HELP!!!!
« Reply #1 on: 06 February 2011, 16:41 »
this was happenin in my 1.8t sorry cant help you as i never found out what the problem was the engine seized  :cry:but not from that pickup pipe was blocked
Offline new to vw
« Reply #2 on: 06 February 2011, 17:20 »
after you have run the car and stopped it are you getting fuel to the cylinders????
check that you are getting spark and fuel at the engine...
5 door 1.8t AUM
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #3 on: 06 February 2011, 17:31 »
check for spark.. check for fuel pump priming..
Offline houston
« Reply #4 on: 06 February 2011, 17:37 »
sounds like crankshaft sensor problems, get it scanned
Offline navmk4gti
« Reply #5 on: 06 February 2011, 17:42 »
might sound long shot but could it also be blocked up fuel filter.. only about £5 to get  :undecided:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #6 on: 06 February 2011, 18:05 »
that would affect it from first start up as well not just after its fully warmed up..
Offline richw911
« Reply #7 on: 06 February 2011, 18:49 »
+1 or the fuel pump relay  :wink:
Offline kevjenkins
  • VW ITS A RELIGION
« Reply #8 on: 06 February 2011, 20:50 »
So where would i find the crankshaft sensor ? Would it be by  the bottom pully ? cause i have a oil leak of which i need to get sorted ! Could this be cause by oil on my sensor????
Cause i will be getting the oil leak sorted like asap!
Offline richw911
« Reply #9 on: 06 February 2011, 21:17 »
Is there any fault codes?
http://forums.vwvortex.com/showthread.php?3864951-DIY-cam-positioning-sensor-%28hall-sensor%29
