Author Topic: '94 MK3 16v Gti rough running when cold. ECU Temp Sensor?  (Read 6048 times)
Offline burstlikeabubble
My golf runs rough when cold and is fine when warm and from what i have read it could be the ECU Temperature sensor.
I have the new sensor in my hand but cannot find it on the engine anywhere to replace it. Can anyone tell me where it is and if i am going in the right direction?
By the way the temperature gauge seems to be working fine and the digital temp display on the right stalk only states a temp when 50 degree celcius and above is this normal?
Thanks
Phil
Re: '94 MK3 16v Gti rough running when cold. ECU Temp Sensor?
« Reply #1 on: 06 February 2011, 14:37 »
By the way the new part i have in my hand is this:
http://partfinder.smpeurope.com/index.html?p=156&partid=52302&from=153&recordset=208&value=52302
Here is my engine
I have found a small sensor on the right hand side of the engine but it is different to the new one i have.
« Last Edit: 06 February 2011, 15:01 by burstlikeabubble »
Offline muzo26
« Reply #3 on: 07 February 2011, 14:48 »
thats the wrong sensor, looks like a mk2 or mk3 8v sensor to me. go to vw for this one:
026 906 161 - temp sensor, white, m10x1 - 32.24+VAT
« Reply #4 on: 08 February 2011, 17:52 »
Yeah it was the wrong one.
I am going to clean the idle valve up by soaking it in petrol for a couple of hours and see if that makes a difference.
If it doesn't then I will try unplugging the airflow meter and see if it performs better. Can't afford a new airflow meter mind and I am guessing second hand ones will be a bit hit or miss so we will have to see  :smiley:
Offline Khare
  • The bear that khares
« Reply #5 on: 08 February 2011, 17:58 »
16v has no airflow meter. Just intake air temperature sensor.
I suggest you clean ISV as you're doing already, clean the throttle body, and replace the coolant temp sensor with the one rubjonny posted, it's the safe bet (VW).
