Author Topic: temp sensor (faulty) ?  (Read 1221 times)
Offline daz veedub
  • Operation 1.8t bolf
« on: 05 February 2011, 16:26 »
i replaced temp sensor few weeks ago (genuine vw)  and temp gauge was still sitting on 70, so monday just gone had cambelt, waterpump and thermostat change, plugged in fault code reader an code 16500 engine coolant temp sensor....implausible signal, am guessing its a faulty temp sensor, if its the case then will contact vw and ask them to change for another as i still have the receipt..
or could it be something else ??
Offline richw911
Re: temp sensor (faulty) ?
« Reply #1 on: 05 February 2011, 17:47 »
Faulty unit or wiring  :undecided:
jamie16v
« Reply #2 on: 06 February 2011, 11:31 »
did you delete the code and see if it came back?..
silly question i know..
Offline andc1
« Reply #3 on: 06 February 2011, 11:40 »
i had this, i unplugged the battery for 30 ish mins, never came back for me
Offline daz veedub
« Reply #4 on: 06 February 2011, 11:46 »
yeah deleted and came back, going out there in a min will dissconnect battery try that, also need check if theres a plate in boot or underseat 2 get to fuel pump otherwise its tank off jobby  :sad:
Offline houston
« Reply #5 on: 06 February 2011, 11:49 »
Disconnecting battery wont wipe codes, and there's an access panel for tank pump under the rear seats.
I'd try takin sensor back, if that dont work then check wiring
Offline daz veedub
« Reply #6 on: 06 February 2011, 11:54 »
you,ve just save me going out in gale force winds houston regarding gettin to fuel pump, av wiped the code will check wiring if not ill get vw to swap for a new 1
