Author Topic: Butchers at this DX wiring diagram  (Read 8738 times)
Offline SoundillusioN
Re: Butchers at this DX wiring diagram
« Reply #10 on: 08 February 2011, 18:33 »
Well the van has been sat for 7 years in total really! It was running last year but didnt drive and it got left whilst i moved place etc. Nothing done to car but wont start at moment.
I had added a little fuel but to be honest most prob used when ticking it over last year. I disconected the fuel pipe from the tank and only a little ran out so im thinking it needs some fresh. The old filter and the little inline one were absolutely filthy and the colour of the fuel as in my vid is very dark.
I checked timing and its fine, and unchanged from when running a year ago. I have changed the metering head as I had bought a few second hand ones previously. The vid was with the metering flap help fully open. Touch wood it just needs fresh fuel and restrictive inline filter removed. If that doesnt sort it im going to try and source a fuel pressure tester.
I am off for a week on half term soon so will get a nice long chance to nosey about, so no doubt youll see more of be then :)
Sounds the same as my situation, engine was out of the car for 6 years.. pretty much forgotten about.  :lipsrsealed:  I couldn't start mine when it was all back together..  got really pee'd off at one point.. turned out to be knackered wiring and an over complicated faulty alarm system, hence why I stripped it all out.. by the sounds of it you're pulling all sorts of crud from the bottom of your tank.
The fuel filter like the one in this picture......
......needs to stay in place but i'd recommend replacing it and I have no idea why there is a second, small inline one.  as you say, loose that, is it even correct for a high pressure system?
Because of my crud in old fuel paranoia I put at least 4-5 cans of fuel in before I stated messing and always keep it topped up while it's not moving to prevent the inside of the tank corroding.
Offline bmouthboyo
« Reply #11 on: 09 February 2011, 21:28 »
Yea I replaced that one on the metering head last year before getting it started, lots of crap ran out when I did so was pleased it at least caught most of it. The small inline one I have no idea, hopefully ridding of it will allow the fuel pump an easier ride.
Problem with the T25 fuel tank is you cant get into it to clean etc so going to try and flush as much crude out as i can and hope (pray) the filter catches most of the crap. Ill let you know how it goes :)
« Reply #12 on: 09 February 2011, 21:58 »
Yeah, get rid of that inline one, take a photo first though as i'm curious.
Not sure what tanks you can get inside of these days, it might be worth removing it and opening the plate for the fuel sender as thats a pretty big hole to get to the inside of it to have a butchers and maybe get some crap out.  That's assuming your tank is similar to mine.
Offline bmouthboyo
« Reply #13 on: 22 February 2011, 17:23 »
Here is the removed gammy pre pump filter.
As you can see a fair amount of red crap seems to have been stopped from entering the rest of the system.
Inside the tank is not as bad as I thought it would be:
But still a few bits of red stuff.
Is removing a filter like this a wise idea ???  :huh:
« Reply #14 on: 22 February 2011, 17:48 »
sorry i didn't realise it was pre pump, i though it was inline in the bay somewhere, perhaps not worth loosing but defo worth replacing.
Not sure what that red cr@p is but I think it would be wise to forget the fuel that's in there, drop the tank out and disconnect everything from it, get rid of that fuel and give the tank a good flushing out with a hose. Keep it somewhere warm and let it dry for a couple of days, make sure it's dry before you refit it and get some fresh fuel in there. :afro:
Offline bmouthboyo
« Reply #15 on: 22 February 2011, 18:25 »
Yea sorry mate it is a inline pump, I meant pre pump filter as in its the one before the pump not the later proper one in the engine bay, my bad lol
I have dropped the tank, good idea about flushing it ill do that tomorrow .
