Author Topic: Rear End Finished! But Bulb Error Light Up!  (Read 19570 times)
Offline KennyGTI
« on: 03 February 2011, 13:17 »
Well my LED number plates bulb units arrived today and got them fitted! Look great although will need to see once the darkness sets in tonight.
Getting a bulb out error up though!  :cry: They shouldnt be bringing up any errors as they are fitted with resistors.
Is there anything I can do via VAGCOM to stop the car checking this when starting the engine? I can remember reading about a cold start check and being able to turn it off? Any VAGCOM guru's out there???  :undecided:
APR Stage 2+
Offline The Doc
  • E63s Estate - Vito Sport
Re: Rear End Finished! But Bulb Error Light Up!
« Reply #1 on: 03 February 2011, 18:36 »
Lucky man, I had my VCDS in my boot  :wink:
I ***Think*** this is correct
Cent. Elec.
v
Coding
v
Long Code Help
v
Byte 23
v
Bit 6 NO tick
Let me know  :wink:
Offline am1w
« Reply #2 on: 03 February 2011, 21:04 »
Offline KennyGTI
« Reply #3 on: 03 February 2011, 21:12 »
Thank you so much Doc! I will give that a try tomorrow after work and let you know.
I know Asker, I would take pics but it actually blowing a hurrican outside! Took half my garden fence down today  :cry: Think my neighours would think I was mad if I was out taking pics but all I can say is they are very bright and look fantastic! Pics will arrive tomorrow night  :smiley:
APR Stage 2+
Offline Buck
  • Das Auto
« Reply #4 on: 04 February 2011, 00:03 »
Kenny
I've had these on mine for some time now as it was the first upgrade I did !! They do loook sooo much better
Bought them from alltronix but they are now intermittently coming up with a bulb error although the reason I bought this set was that they are supposed to be error free - they have said I can return for checking and swap out  :wink:
Offline The Doc
« Reply #5 on: 04 February 2011, 20:58 »
I've ordered some from VW, as per the norm they are on.......backorder  :sad:
Offline MAW73
  • Used to like Golfs :-)
« Reply #6 on: 04 February 2011, 21:29 »
What's the vw pt no for these Doc and do they need coding in to work without buld error? Thanks Martin
2014 BMW F20 M135i, Auto
Offline KennyGTI
« Reply #7 on: 04 February 2011, 21:38 »
Surely they will need coding as they are LEDs? Wonder if the code will work with mine, as I am still getting bulb out error.
APR Stage 2+
Offline The Doc
« Reply #8 on: 04 February 2011, 22:20 »
I'll dig out the part number, I have no idea if they work out of the box, I'll hazard a guess not  :sad:
Offline DRC
« Reply #9 on: 04 February 2011, 22:44 »
I had a similar issue with my HIDS on my old Seat Leon, it seems to be the newer CANBUS wiring systems, even with warning cancellers, they would either go out or the error would come up. As posted, VAG-COM seems to be the only way.
'13 Audi A3 8V S-Line - Dakota Grey - 2.0TDI 150 - MMI Plus Nav - Bang&Olufsen - Comfort Pack - LED Lighting Pack - Comms Pack - Model and Technology Badge Deletion
