Author Topic: oil in coolant 2001 2.0 gti  (Read 1042 times)
Offline pommy1968
« on: 02 February 2011, 14:49 »
hi can any one tell me if oil in the water is due to the oil cooler or head gasket or even cracked block many thanks
Re: oil in coolant 2001 2.0 gti
« Reply #1 on: 02 February 2011, 15:10 »
could be the oil cooler, common issue on mk2/3
Offline laurenceg
« Reply #2 on: 03 February 2011, 19:04 »
Most likely problem is the oil cooler just above the oil filter. You can do a sort of test on it without any pressuretesting equipment. Take it off the car, leaving the coolant hoses on. It comes off easily, there's just one nut screwed onto the same thread as the oil filter goes onto. Then prop it up with both hoses facing upwards. Carefully fill up the coolant side of the heat exchanger until the lower of the 2 hoses overflows then leave it for an hour or so. If the level has gone down it's obviously leaking.
I'm not saying this will pick up leaks which only leak under pressure but this was how I found mine was leaking.
Best of luck.
« Reply #3 on: 04 February 2011, 09:40 »
other option is to disconnect the hoses from it and bridge them together somehow. then flush the coolant out with a hosepipe, fill with plain water and a cupfull of bio washing powder. run the engien till the thermostat opens then allow to cool then drain & flush again. once oil is all gone fill it back up and drive it, if the oil comes back the issue isnt with the oil cooler. oil leaking out of the oil cooler outlets is a givaway too
