Author Topic: g60 into mk3  (Read 2815 times)
Offline tshirt2k
  • Been there...Done that...
Re: g60 into mk3
« Reply #10 on: 04 February 2011, 08:24 »
It will still give around 170hp on these. Could get you running until you want more boost.  Only thing is, they produce quite a bit of heat in the process. It's been done also without reducing compression on standard 2L 8v at low boost. This ideally needs better engine control with standalone PCM.
M62 will give more output with less heat. Not keen on the whining they produce though.   :sick:
Mk3 ABF 16VT Megasquirt V3
Offline panzer V
Re: g60 into mk3
« Reply #11 on: 05 February 2011, 11:11 »
thanks guys for advice  :smiley:
looks like im picking engine up next weekend then straight down me m8s workshop to get it cleaned and stripped down ready to inspect it
so will defo be on your cases so i can get it done right 1st time lol
Offline A7 UFO
Re: g60 into mk3
« Reply #12 on: 07 February 2011, 07:25 »
a mate of mine did this to his mk3 years ago.
