Author Topic: Gearbox / clutch noise  (Read 7786 times)
Re: Gearbox / clutch noise
« Reply #10 on: 02 February 2011, 14:03 »
i would call that the input shaft bearing :)
this would be my thought too but since its happened on 2 gearboxes I'm not so sure! possible the rebuilt box wasnt done properly so it had the same issue...
Offline AudiA8Quattro
« Reply #11 on: 02 February 2011, 18:17 »
So isn't there a bearing on the end of the crankshaft(flywheel end)?
« Reply #12 on: 02 February 2011, 18:24 »
Pilot bearing is no.19 in the picture i believe, no part number listed though.
http://www.vagcat.com/epc/cat/vw/GO/1996/166/49/1959196/#19
Anyway i'm sure Jon will correct me if my information is wrong   :smiley:
« Last Edit: 02 February 2011, 21:45 by AudiA8Quattro »
Offline Munson
« Reply #13 on: 02 February 2011, 18:45 »
Thanks again for your replies guys. Will speak to garage n see if they can check any of the suggestions. Will let u know the outcome, hopefully be back on the road soon!!!
Offline Munson
« Reply #14 on: 07 February 2011, 19:15 »
Well gearbox went back in today and car is running sweet and all abnormal noises have disappeared! Happy days! The garage didn't do anything other than fit the gearbox so can only assume there was something wrong with the first reconditioned gearbox I received. Will be having words with the supplier as I've spent a fortune on additional labour and transport, suspect I'll be p*ssing in the wind with regards to being compensated but will see what happens, just glad to be back on the road again after 6 weeks of misery! Thanks again to everyone, happy motoring!
« Reply #15 on: 08 February 2011, 10:07 »
Thats good news that its fixed, but not so that you got ripped off :(
sopunds liek the input shaft bearing wasnt replaced, or they didn't set the shaft bearing preloads inside the box properly  :angry:
No there isnt a pilot bearing on a 020 setup, the input shaft only reaches the clutch friction disc. its cos the 020 clutch is all arse about face, release bearing is in the back of the gearbox, and the pressure plate is bolted to the engine first, then the release plate, then friction disc and finally the flywheel.
there isnt any access thru the middle of the clutch to the crank either, the pressure plate and release plate cover it all up :)
« Reply #16 on: 08 February 2011, 12:58 »
I should actually know all of that.
I've done both types of clutch, so know exactly how they work  :grin:
Problem is, its been too long  :tongue:
« Reply #17 on: 08 February 2011, 14:44 »
its age catching up with you :P
will be happening to me soon as I've just turned 30. I wont be able to resist the pull of the garden centre and cardigans with patches on the elbows forever!
« Reply #18 on: 08 February 2011, 17:28 »
I've just moved onto more complicated cars  :sick:
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #19 on: 08 February 2011, 19:43 »
