turn the head and block to TDC, then you can refit the head no bother. main thing is your dizzy is gonna be out now, so remove the dizzy cap and make sure the rotor arm is lined up to the notch mark once the belt is back on. then move the leads so #1 is where the rotor arm is pointing and then follow the relavant ignition timing guide for the engine
