Author Topic: 8v Digi heater problem  (Read 1190 times)
Offline GolfDan
« on: 27 February 2005, 09:48 »
Could anyone please give me some clues as to what is wrong with my motor? The heater is blowing cool/cold air after I have been sitting in traffic for a short while and then warms again after the engine temp drops! I'm no mechanic so havet got a clue what to do for the best.
Cheers in advance
free
Re: 8v Digi heater problem
« Reply #1 on: 28 February 2005, 16:24 »
sounds like it could be air in the system,
when its cold take cap off header.
put heater on full hot, and the fan on max
start car n when its warm air should stard bubbeling up
but when mind did it had 2 help it a bit, so jamed the throttel open a bit with a brick, at about 2000rpm,
just a fast tickover,
that sorted the job :wink:
Offline Chris Green
« Reply #2 on: 28 February 2005, 16:43 »
My car has a similar problem.
The heater is very inconsistent, most of the time it is cold.
Does the car have to be completely cold before I remove the header cap? or would it be alright if I just left it for a little while? I understand there is a bit of pressure in the tank while the car is hot.
It is an 86 kjet.
