Author Topic: Fuel pump  (Read 4835 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Fuel pump
« Reply #10 on: 31 January 2011, 17:46 »
I don't have a TPS over here  :sad:
I'd rather have in tank myself, the Walbro in tank pump is what a lot of people have probs with as the pick up doesn't fit down far enough so you get starvation
Walbro external is £77 delivered, how much was the LCR pump?
Offline Hulmie
  • White MK4 1.8T AGU K03s
Re: Fuel pump
« Reply #11 on: 31 January 2011, 17:48 »
leon cupra r one is £140 when i priced it up.
Just make sure your looking at a walbro 255lph pump and not a 225lph pump
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Offline tech1889
  • Mk2 GTI FTW !!
Re: Fuel pump
« Reply #13 on: 31 January 2011, 18:01 »
as the LCR is double cant you get a secondhand unit ?? if not just get the walbro lol but you will then have 2 pumps wont ya ??
Offline Hulmie
Re: Fuel pump
« Reply #14 on: 31 January 2011, 18:11 »
the standard pump will only be used as a pick up point and the walbro will be the one doing the pumping.
one thing i was looking at was if a r32 fuel pump would fit and what the flow rate is but struggled to find the info.
Offline tech1889
  • Mk2 GTI FTW !!
Re: Fuel pump
« Reply #15 on: 31 January 2011, 18:13 »
Will autodata have the info if so i will check..
Offline tech1889
  • Mk2 GTI FTW !!
Re: Fuel pump
« Reply #16 on: 31 January 2011, 18:17 »
R32 not on my Autodata... Have you considered a TT fuel pump ??
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Fuel pump
« Reply #17 on: 31 January 2011, 18:23 »
There is a second hand unit on ebay for £60...
TT/S3/LCR pumps are all the same I believe
Offline tech1889
  • Mk2 GTI FTW !!
Re: Fuel pump
« Reply #18 on: 31 January 2011, 18:25 »
i would get that seconhand unit tbh mate it will be more than good enough.. ask how many miles the car had done it came off..
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Fuel pump
« Reply #19 on: 31 January 2011, 18:44 »
54k :smiley:
Might wait until the RR day on Sat to see how the fuel ratio is doing on a full throttle run
