Author Topic: GTD Fog Lamps Condensed - common problem? How to sort  (Read 7779 times)
Offline Phil1980
Re: GTD Fog Lamps Condensed - common problem? How to sort
« Reply #10 on: 29 January 2011, 08:13 »
I had a problem on one of my brake light units with condensation, removed it heated with a hairdryer to evaporate the moisture and used silicone sealant to reseal the unit.  Have not had any problems since.  Should be easy enough to remove a fog light unit and do similar, of course if its under warranty take it straight back let the dealer sort it.
MK5 2005 GTI, BLACK, 3 DR, 18" MONZA II, XENONS
Offline darrens
« Reply #11 on: 29 January 2011, 08:27 »
I have this problem too with my front fog light units, spoke to my local dealer and they are being replaced under warranty this week.
Offline ajmoir36
« Reply #12 on: 29 January 2011, 14:07 »
I had this with one of my taillights removed it radiator for two days and replaced it, no problems anymore.  It was loaded with water, the seal fell out when I removed, so I figured it was badly fitted and refitting it properly fixed the issue.  VW will probably take your car run the engine and run the lights until the heat dries it up, wasting petrol/diesel.
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline Phil1980
« Reply #13 on: 29 January 2011, 17:04 »
If its under warranty surely they should just replace the unit be it a tail light or fog light.
Offline Buck
  • Das Auto
« Reply #14 on: 29 January 2011, 17:09 »
Well I've had the fogs on whilst driving today to see if the bulb heat would help them dry out
They are much better but still not right so will try this again and see if they do indeed dry out.  If I can't get them dry or the problem then returns its off to the dealers
Offline Buck
  • Das Auto
« Reply #15 on: 19 February 2011, 11:46 »
Result !!
Car goes in a week on Monday for new fog lamps under warranty. no hassle. Told him I'd had fogs on trying to clear. He said slight condensation is common/acceptable but mine were "bad" - any more than 20 mins to clear is warranty issue he commented
Offline am1w
« Reply #16 on: 19 February 2011, 11:53 »
Result !!
See what happens when you don't wear RED lipstick!  :grin:
Offline Buck
  • Das Auto
« Reply #17 on: 19 February 2011, 12:01 »
 I find it useful to go in with the approach of "this needs to be done under warranty but you'll need to see it first before I book it in."
He did say as it's a bumper off job it's a couple of hours work - glad I'm not paying them for their slowness!
Offline GolfTi
  • ..gotta feel for my automobile..
« Reply #18 on: 25 March 2011, 21:30 »
Try a search on GTI Fog Lamps
Mk7 GTI. DBP, DCC, Winter pack. Mine since new, July 2013.
GTI no. 4. Golf no. 5.  VW no. 7.
Offline am1w
« Reply #19 on: 25 March 2011, 21:36 »
Adrian: Do you think the rattling diesel is causing the fog light housing problem?  :evil: :grin:
