Author Topic: mk2 fuel pump  (Read 1681 times)
Offline woody1
mk2 fuel pump
« on: 27 January 2011, 17:12 »
hi ive got a mk2 gti fuel pump with standard fuel tank runing a vr6 engine but the fuel pump stays runing all the time is it spost to do this ?
or can i have it so it clicks on then off ? its allso got a 4 bar regulator if that makes any difference ?
cheers woods
......THE 6 CYLINDER CURB CRAWLER......
Re: mk2 fuel pump
« Reply #1 on: 28 January 2011, 11:13 »
no its not, what pump relay have you got fitted? should be 67, 80 or 167. bottom right slot if CE2 (hazard switch on column) or slot 2 if pre-90 (hazard switch on dash)
http://www.golfgtiforum.co.uk/index.php?topic=44637.10
Offline woody1
Re: mk2 fuel pump
« Reply #2 on: 28 January 2011, 18:05 »
its a 167 an the hazards on the steering 1990 h plate ? :huh:
Re: mk2 fuel pump
« Reply #3 on: 28 January 2011, 23:25 »
It should run all the time the engine is running, on turning the ign, it should prime and thats is it.
Offline woody1
Re: mk2 fuel pump
« Reply #4 on: 30 January 2011, 15:14 »
when i turn ignition it comes on and stays on untill you turn car off ?
it has the 167 relay in so dont get it ?
Re: mk2 fuel pump
« Reply #5 on: 30 January 2011, 19:05 »
Sounds like the relay is sticking try another if you can
Re: mk2 fuel pump
« Reply #6 on: 31 January 2011, 15:15 »
i wonder if the earth trigger from the ecu has just been grounded somewhere. gonna be a tricky one to track down!  the issue is if you have a crash the pump wont cut out, so its a safety thing.
look at fusebox pin G1/3, see if its been spliced to ground somewhere. if it goes off into the engien loom then you'll have fun tracing the issue.
http://www.golfgtiforum.co.uk/index.php?topic=44637.20
try a new relay 1st tho :)
Offline woody1
Re: mk2 fuel pump
« Reply #7 on: 31 January 2011, 21:36 »
cool cheers dudes will try relay looks like a pretty old one in there
