Author Topic: peak boost judder..  (Read 2571 times)
dellenty69
Re: peak boost judder..
« Reply #10 on: 28 January 2011, 13:53 »
just changed fuel filter old one was clean as a whistle, and the new one hasn't done feck all. lol
new ideas?
dellenty69
« Reply #11 on: 28 January 2011, 15:06 »
oh how exciting, i finally got the engine management light come on!
2 codes
16684/P0300/000768 - Random/Multiple Cylinder Misfire Detected
Possible Causes
Air Intake System leaking
Fuel Supply faulty
Injector(s) faulty
Ignition Cable(s) and/or Spark Plug(s) faulty
Ignition Coil(s) faulty
Exhaust Gas Recirculation (EGR) Valve (N18) stuck/open
Camshaft Position Sensor (G40) faulty
Possible Solutions
Check Misfire Recognition
Check Air Intake System
Check Fuel Supply
Check Injector(s) and Injector Sealing
Check Ignition Cable(s) and Spark Plug(s)
Check Ignition Coil(s)
Check Exhaust Gas Recirculation (EGR) Valve (N18)
Check Camshaft Position Sensor (G40)
Special Notes
This DTC indicates that one or multiple cylinders are misfiring, but the ECU fails to identify the cylinder.
and
16685/P0301/000769 - Cylinder 1 Misfire Detected
Possible Causes
Ignition system
Fuel injectors
Fuel pressure
Running out of fuel
EVAP canister purge valve
Evaporative emission system
Low compression
Base engine problems
Controle Module damaged
Special Notes
This feature search for engine misfire in a specific cylinder. Most of the time the cause for a misfire is a lack of combustion in a cylinder due to absence of spark, poor fuel metering, or poor compression.
time to hunting.... :(
Offline dr. benway
« Reply #12 on: 28 January 2011, 15:26 »
Fuel filter is under the car towards the rear.  You're on about the charcoal canister which is next to your washer bottle  :smiley:
Diesels have the fuel filter in the engine bay  :smug:
hey rhyso, can you tell me what this does..... dont laugh either!!!!   :embarassed:
Not 100% tbh - think its something to do with the emissions control.  I stand to be corrected.  Petrol engines are not my forte
They're used for impromptu barbecues
Offline topher
  • Administrator
  • fully functioning
« Reply #13 on: 28 January 2011, 15:27 »
sounds like coilpack on cylinder 1 has broken down (furthest one to the left as you look at the engine from the front of the car)
try swapping the coils around between cylinders 1 and 2, and see if the fault code jumps to the next cylinder aswell.
dellenty69
« Reply #14 on: 28 January 2011, 16:45 »
well iv just swapped them over cy1 with cy2 and now it wont throw a fault code up no matter how hard i try.
just have keep driving till it does.
