Author Topic: Gas or oil filled shocks  (Read 5312 times)
Re: Gas or oil filled shocks
« Reply #20 on: 21 February 2011, 21:34 »
Any idea what it could be then thats squeeking.. When I refit the struts I lower the car back down on its wheels before tightening the top bolts up in the boot.... Am I right in thinking they shouldn't be done up too tight and just tight enough to bite....
They should be tight and from memory you should have another nut on top as well. :smiley:
Offline leegt5
« Reply #21 on: 21 February 2011, 21:39 »
Yeah theres 2 nuts per strut inbetween washer type things small top mount and top gold plates !!
Any idea what sort of torque they need to be done up to then as that may be the problem...
Cheers Wayne..
« Reply #22 on: 21 February 2011, 21:43 »
Cheers Wayne..
No idea on torque, I just nipped mine up.
Offline leegt5
« Reply #23 on: 21 February 2011, 22:17 »
Oh ok then... All i've done is nip them up !!
« Reply #24 on: 21 February 2011, 23:49 »
Has it worked  :smiley:
Offline polo6n222
« Reply #25 on: 22 February 2011, 12:21 »
that sounds like what my car is doing
Offline Len
« Reply #26 on: 22 February 2011, 13:21 »
Any suspension member should be tightened as much as possible. You only want the parts that should move to move!
www.sas.org.uk
www.the-ace.org.uk
Offline leegt5
« Reply #27 on: 23 February 2011, 10:40 »
Anyone got a picture of a built standard rear strut ?
