Author Topic: Waaah Misfire!  (Read 1558 times)
Offline Bubbles_GTI
Waaah Misfire!
« on: 23 January 2011, 13:14 »
Hi All
Well, everything was going just fine until i decided to service our V reg 2.0 GTI.  New plugs, oil, oil filter, and air filter.
Now when its ticking over it sounds fine and when it's revved its ok but when it's driving and you boot it, it stutters and when it's under load (when I have it in 3rd, when it should be 2nd gear) it also does it.  Ive made sure the plugs are in tightly and the leads are on correctly.  I'm also going to check to make sure ive not accidentally detached one of the HT leads from the metal part that goes over the plug.
Failing that I have no idea what could be wrong as as I'm pretty crap at car stuff i'm not sure what to do next.....?
Oh, the ABS light is on but the levels, pads and discs are fine.  Is there a vacuum pipe that could be off (i read that that can effect the mixture)  Also the plugs are also very soot covered already and its only done 10 miles since I changed them  :tongue:
Any help would be appreciated
Jim
Offline javalin
Re: Waaah Misfire!
« Reply #1 on: 23 January 2011, 14:30 »
sounds like you could have an air leak as you say.  Did you gap the plugs?  What make plugs did you put in it?  (cheap parts can cause misfires)
co-incidental possibly?  Need a code read to see what its moaning about.
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Bubbles_GTI
Re: Waaah Misfire!
« Reply #2 on: 23 January 2011, 14:39 »
Cheers James....
The plugs are Bosch but no, I didn't gap them.  The ABS light was on before all this happened so maybe just a coincidence.  I'm sure it's plug/lead related but maybe i'm missing something..........?
Offline javalin
Re: Waaah Misfire!
« Reply #3 on: 23 January 2011, 14:41 »
tried putting the old leads back on?  Are they the 3 or 4 electrode - in which case they don't need gapping anyway!
J
Offline Bubbles_GTI
Re: Waaah Misfire!
« Reply #4 on: 23 January 2011, 14:57 »
Yeah i'll give that a go. Also, the plugs were 2 electrode...the ones that came out were 3.
cheers mate..........
Offline Bubbles_GTI
Re: Waaah Misfire!
« Reply #5 on: 23 January 2011, 15:35 »
Unbelievable! Put the old plugs back in and it goes like a rocket! Wrong effing plugs! lmao.
Offline javalin
Re: Waaah Misfire!
« Reply #6 on: 23 January 2011, 16:23 »
Good news.  When it doubt put it back as was and retest.
Does it run ok with new leads and old plugs?
Cheers,
James
Offline Bubbles_GTI
Re: Waaah Misfire!
« Reply #7 on: 23 January 2011, 16:25 »
Yeah absolutely fine.  I'll get some correct new plugs and start again lol!
Offline new to vw
Re: Waaah Misfire!
« Reply #8 on: 23 January 2011, 18:44 »
probly 1 or 2 of the leads are not connecting with the plugs properly or they are not gapped properly
5 door 1.8t AUM
Offline danny_p
Re: Waaah Misfire!
« Reply #9 on: 24 January 2011, 00:10 »
you do get sh!t plugs out the box,   imo those 3 prong ones are crap anyway   singel electrode NGK's all the way here
all the VW's have gone bar 1.
