Author Topic: People with TDI Golf's - I think i have a problem  (Read 18597 times)
Offline Snoopy
  • Moderator
  • Geoff.
Re: People with TDI Golf's - I think i have a problem
« Reply #10 on: 21 January 2011, 21:01 »
Thanks.  :evil:
Current Garage:
35+ years of GTI ownership.
Offline Agreeable Slick
  • Unit
« Reply #11 on: 21 January 2011, 21:09 »
I've read reports on bad fuel con for the 1.6 TDI.
http://www.golfmk6.com/forums/showthread.php?t=12424
As for the oil temp if I cruise at 70mph on a motorway and I switch to oil temp on the MFD is show 96 C its all relative to speed and load on the engine.  :wink:
Cruising at 70 is barely a load on the engine at all until you are accelerating. :wink:
Diesels are heat engines, they will naturally run hotter than normal, usual operating temps are 80-100degrees.
Offline Keithuk
« Reply #12 on: 22 January 2011, 01:05 »
Yes all engines are heat engines. The closer to 100 C your can run the engine the more efficient it is.
That wasn't my point the OP asked about the oil temp.  :wink:
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline evo1986
« Reply #13 on: 23 January 2011, 19:28 »
As people on here know I work for vw, I have driven every type of mk6 tdi. The 1.6tdi is an awful engine, I had a revo'd mk6 gtd last year and that was more economical than any 1.6 tdi or blue motion I have driven since. Had a customer reject the car after delivery because he was so disappointed with it and swap from 2.0 140 now he is getting better economy.
Sales Manager
WhatsApp: 07389107119
