The garage
Has anybody used this brake bleeding kit before?
Topic: Has anybody used this brake bleeding kit before? (Read 1528 times)
LowlifeDubber
19 January 2011, 15:20 »
Ive just bought this brand new and it got delivered today with no destructions
I have a rough idea how it works but can't find any info on the web.
It will be handy for when the missus isnt here and i want to bleed on me own.
http://www.amazon.co.uk/Draper-71205-Universal-Brake-Bleeding/dp/B001FCLZLK
LowlifeDubber
Re: Has anybody used this brake bleeding kit before?
19 January 2011, 15:37 »
I thought id put it in the garage.My bad
AudiA8Quattro
Forum addict
19 January 2011, 17:50 »
I bought this, no air compressor needed.
http://cgi.ebay.co.uk/SEALEY-Brake-Clutch-Bleeder-Bleeding-System-Kit-VS820-/200564089238?pt=UK_Air_Tools_and_Compressors&hash=item2eb28d2196
Highly recommended
LowlifeDubber
19 January 2011, 18:29 »
Great stuff,i have got a compressor and have just bought the one i posted.Just dont know how to use it
Im guessing it works on a vacuum and you press the trigger on the gun to suck the fluid through the bleed nipple.Although im not sure and dont fancy blowing the top off the master cylinder
emery1990
19 January 2011, 21:46 »
Does it attach to to master cyliner then pump the fluid out the opened nipple, my little eezi bleed done this via an inflated tyre. Do you pump up the pressure?
LowlifeDubber
19 January 2011, 21:48 »
Its via a compressor and runs at about 70psi i think it works on a vacuum,sucking out the fluid through the bleed nipple.But i want to make sure 1st as i dont want to blow a load of air into the system.
The garage
