Author Topic: 13 yes13 MPG  (Read 2232 times)
Re: 13 yes13 MPG
« Reply #10 on: 18 January 2011, 10:52 »
when you say the screw does nothing, did you have the digi in setup mode while you were playing with it?
Offline rob.043
Re: 13 yes13 MPG
« Reply #11 on: 18 January 2011, 16:26 »
temp only ever reads  1/4 of the gauge  so i guess that could be part of the problem ill change the stat
im having trouble finding an afm and dont have a multimeter to check the resistance
The temp gauge often reads low, there is a seperate sender for it, thats not connected to the ECU. Both the blue (ECU) and black (gauge) senders can be bought from VW for not much money, and are a safer bet than non genuine ones. Get a couple of sealing rings with them too, or you may get a poor seal in the coolant housing.
May be worth getting a wee multimeter, they aint to expensive either....
Offline rob.043
Re: 13 yes13 MPG
« Reply #12 on: 18 January 2011, 16:28 »
sorry, you have a good blue one already. Did you re tune it when you fitted this?  Running through the tuning guide in the maintinance section would be a cheap place to start.
