Author Topic: mk4 daash into mk3  (Read 1858 times)
Offline davies1644
Re: mk4 daash into mk3
« Reply #10 on: 17 January 2011, 16:57 »
i found someone that said he didnt chop the dash as he was using an aftermarket steering wheel so he just put it in but dunno if thats right?
« Reply #11 on: 17 January 2011, 17:14 »
The wiring is the bigger problem
Offline Jimp
« Reply #12 on: 17 January 2011, 17:44 »
It will need to be trimmed at both sides too as it is too wide. IIRC you need to modify the steering rack too. I forget if there are issues with getting the centre console and gearstick/handbrake area to meet and look decent. Then there's mating all the mk4 wiring to the mk3 wiring. It's a lot of work but worth it if you are doing a mk4 engine swap too.
Not low enough mk5
Not on the road enough mk3
Offline jonnypolish
  • t2871r needed :)
« Reply #13 on: 17 January 2011, 18:20 »
Jimps correct, the steering rack also needs to be extended!
 MK2 VR y0!
