Author Topic: Can i run her without PAS pump???????  (Read 876 times)
Offline als2
« on: 16 January 2011, 18:50 »
Got new exhaust fitted only to find her pissing PAS fluid from high pressure pipe.
Can i take the belt off and run her without the pump til i get time to fix it????
Many thanks
AL
Re: Can i run her without PAS pump???????
« Reply #1 on: 16 January 2011, 18:53 »
Steering will be mega heavy,don't think you will manage without it to be honest.
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 16 January 2011, 20:41 »
when moving you wont have many issues...but come to slow speeds/stopping and you'll need some big arms!
Offline Dmonday
« Reply #3 on: 16 January 2011, 20:46 »
Running my VR without one and was okay (when it was running :D) abit heavier then standard car with no pas but not tooo bad!
Dan
Offline als2
« Reply #4 on: 16 January 2011, 20:51 »
drove her home, wasent to bad, reminded me of the good ol days, two hands at ALL times!!!
on the move is actually not bad at all, slow speed needs breaking out the guns!!
Think its the HP line down beside the rack, best place to pick them up??? nice easy job im guessing?????
oh and am i doing any damage running her like this????
All the best guys
« Reply #5 on: 18 January 2011, 10:28 »
scrappy is where i would start. if you can get underneath the donor car you can have the pipe out in half an hour IF its not siezed in. clearance is tight, but as long as it isnt siezed can be done.  did it myself, donor car was easy but when it came to fitting it to the MK2 Golf that needed it i was under there all day, the subframe had to be lowered in the end, joy
