Author Topic: Petrol Bio-ethanol Content  (Read 7241 times)
Offline crazy_e
Re: Petrol Bio-ethanol Content
« Reply #20 on: 17 January 2011, 23:45 »
£1500 for the first outlay and it aparently adds like 500-700 to the value of the car :)
Offline Khare
  • The bear that khares
« Reply #21 on: 18 January 2011, 00:03 »
Hmmm, not sure about that. I wouldn't say I'd buy a £1600 "ok" mk3 with LPG  :undecided:
There's maintenance costs too though.
Offline crazy_e
« Reply #22 on: 18 January 2011, 09:59 »
well to tell you the truth at my garage we fit and maintain lpg systems (dont worry im not going to try and sell it im only an aprentace here) and it is not too bad to be honest cheeper than a normaly service
Offline Stirring Moose
« Reply #23 on: 18 January 2011, 21:48 »
Just got the following on the subject of ethanol in fuel from a Technical Specialist at the AA:
"We are also very concerned about the effects of ethanol.  We have
already received many reports of failure of rubber fuel hoses as a
result of using ordinary petrol with only around three per cent ethanol
content.
Last year we assisted a fuel scientist who was preparing a report on the
effects of ethanol, particularly if the UK does adopt the higher blends.
This was a follow-up to the Fuel Quality Consultation.  The report
should be published shortly and as soon as it is available I'll send a
copy or a link to the website.
In terms of your own Mini, Burlen Fuel Systems in Wiltshire are aware of
the ethanol issue and have ethanol resistant parts in stock.  The
situation with the Golf is less clear, but I am trying to establish
whether you are likely to experience any problems and will let you know
when I send the report."
S.M.
Love and hate, war and peace, joy and sadness... all just crap that happens between trackdays!
Offline danny_p
« Reply #24 on: 19 January 2011, 00:49 »
the use of ethanol in petrol is not funny.
ethanol has a lower calorific value than petrol and also require less air to burn a given amount of it.   iirc the afr's for alcohol are around the 6:1 mark
calorific value is about half that of petrol per ltr.   the sh!tweasels in chagrge however won't alter the duity but we will getting less energy from each ltr of fuel we buy.
my guestimation is it'll be about the same as banging the duity up 5%.    as for effects on fuel system i'm not worryed i've pissed about with ethanol and methanol a bit, high concentarions of methanol give problems but ethanol is fine never caused any bother even useing std vw bits
all the VW's have gone bar 1.
Offline Agreeable Slick
  • Unit
« Reply #25 on: 19 January 2011, 08:28 »
content.
S.M.
Did the guy/gal define what cars or fuel systems they had seen this take place on?
Offline robz
« Reply #26 on: 19 January 2011, 10:02 »
some interesting stuff that! thanks for the heads up!!
as danny says though, i bet the price stays the same :(
« Reply #27 on: 19 January 2011, 19:30 »
@ danny_p: Think you might well be right there chap. Hadn't even thought of that. I know that engines which burn 100% alcohol fuels use a lot more than than an equivilent petrol motor so the ethanol/petrol mix would logically knock a bit off the mpg compared to pure petrol.
@ Agreeable Slick: No, no info as to what cars have already suffered. As the message says, the specific situation regarding the Mk.3 should become clearer once this report is out.
S.M.
  • Unit
« Reply #28 on: 19 January 2011, 20:13 »
I would try if you can to get them to disclose this, as I wouldn't be suprised if the cars they have had concerns over a lot older than we think.
until then, I still maintain that there shouldn't be much of an issue.
